Wheel Spacers | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Wheel Spacers
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
call the place up, ask em if its for a pair or for all four . usually its for a pair tho.
2000Xplorer
Parker, Colorado
2000 Explorer XLT
i got the right link
justin146
Oxford, MS-- home of the Ole Miss Rebels
2000 XLT Sport 5.0 Turbo
"Pro-Spacer, Wheel Spacer, Sold Individually, Made Of Aircraft Aluminum Alloy, Bolt Pattern 5x114.3, 70.5 Center Bore/Hub Dia., "
this is a quote from the page... SOLD INDIVIDUALLY
fig
LI New York
1997 eddie Bauer Explorer
spacers
I have those on my explorer. I bought mustang cobra rims(i think they are the 95) To make them fit i bought these spacers(1") They work very well and made my 1997 eddie stance look much better. I've had them for 5 years and not a single problem.
Failed to mention I had to grind the wheel bolts very little. my and 1/8" or even less.
ExplorerDMB
Moderator/Technician
Moderator Emeritus
Mechanicsville, Virginia
2004 Acura TL
wheel bolts? the studs you mean?
-Drew
fig
LI New York
ExplorerDMB
Moderator Emeritus
2004 Acura TL
why would you have to grind down the studs? Are these on the factory studs or the spacer studs?
-Drew
fig
LI New York
the width of the spacers are shorter than the total length of the studs. when you try to put your rims on they will bump into the studs. You will be unable to put the rims flush onto the spacers.
justin146
-Drew
If your spacer's width is not equal to or greater than the length of your stock studs, you will have trim them.
justin146
jinx
fig
LI New York
you would have to grind the stock studs.
2000Xplorer
Parker, Colorado
2000 Explorer XLT
thats a waste of money for one a piece for that price
fig
LI New York
Check ebay for (wheel spacers) seems they have them for alot less
MountaineerGreen
Towing Moderator
Moderator Emeritus
North East Arkansas
2012 F150 4x4
Yeah but when it comes to something like allready somewhat dangerous wheel spacers, do you really want to risk buying cheap stuff? Ive heard horror stories about wheel spacers, so I refuse to use them because I use my Mountaineer for towing. Id like to set my rear wheels out because they seem too narrow, but Id hate to risk a spacer breaking under a load and a wheel falling off at 60 MPH. That would suck.
fig
LI New York
Good point. I can't remember exactly but I believe I paid 110.00 for a pair(5 years ago). They are made in Germany not sure of the brand. I've had no problems with them over the 5 years I've been using them.
