Wheel Swap Question | Ford Explorer - Ford Ranger Forums - Serious Explorations
Wheel Swap Question
CliveWinston
I have run across a free set of basically new wheels and tires. My question is will 16 in Wheels from a 4 door Jeep Wrangler 2wd fit my 99 mountie? ie is the bolt pattern the same? they are both 5 lug
Ray Lobato
Moderator
Moderator Emeritus
2006 Honda Accord
Your Mountineer has a 5x4.5 lug pattern. My Google-fu says that the Wrangler is also a 5x4.5 lug pattern, so you should be good. :)
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
No Mounty no more.
The offset on HEEP's is different than Explorers. There was someone here a couple of weeks ago that had bought HEEP wheels & had tires mounted. When they went to put them on his Ex the wheel rubbed the brake caliper.
CliveWinston
seems like a spacer would fix any clearance issues, as long as the bolt pattern matches up.
Cobraguy
Phoenix...Greatest City on Earth
1995 EB & 1999 EB 5.0
Dan, that sounds more like a diameter issue. Were they trying to do something like 16's where they should have had 17's? (for example) Just curious is all
Dan Whitaker
One fast putty tat
No Mounty no more.
It was a straight 15" swap I believe.
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
Just becareful on the year.. I believe the 06 and newer are now 5 on 5
