Where can I get a GOOD ELM327 reader?
Pete Adams
Ball Ground, GA
2018 Explorer PIU
Callsign
K4PRA
Well after I bought two "Bad Clone" devices I need help. Can someone direct me to source for a good reader that will make Forscan happy? I'm anxious to start personalizing my car.
I'm interested in hearing from someone who recently purchased their reader. These days with clones of clones getting a real compatible device is pretty hard.
Thanks
Pete Adams
Ball Ground, GA
2018 Explorer PIU
Callsign
K4PRA
Thanks for the quick reply fastpakr.
Good info but I should have added that I'm looking for a USB connected device.
Some people have good luck with bluetooth but I haven't.
I sure don't want to brick my car.
Pete Adams
Ball Ground, GA
2018 Explorer PIU
Callsign
K4PRA
Ask and you shall receive.
Just what I'm looking for.
Ain't this a great forum.
Thanks fastpakr.
fastpakr
Roanoke, VA
99 4wd - 5.0/4R70W/BW4406
That's actually the one I meant to buy when I ordered mine. Just wasn't paying attention and grabbed the Bluetooth version by mistake. It's worked great so far, but the USB version sounds perfect for you.
Location
Wisconsin
Port Washington, WI
2017 Explorer Sport
M Where are you buying Ford parts during COVID-19? Stock 2011 - 2019 Ford Explorer Discussion 2
D Where does this plug into? Stock 2011 - 2019 Ford Explorer Discussion 5
S Where to buy a new Key FOB online Stock 2011 - 2019 Ford Explorer Discussion 0
Bobs2018Explorer Where the heck is the trip odometer, in my new 2018 XLT? Stock 2011 - 2019 Ford Explorer Discussion 10
R Need Help With Part Name and Where to Find a Replacement Stock 2011 - 2019 Ford Explorer Discussion 2
D Not sure where to post: I'm too damn tall Stock 2011 - 2019 Ford Explorer Discussion 0
Q Where to grab +12V in Engine Fuse Box? Stock 2011 - 2019 Ford Explorer Discussion 1
G Where Should I Plug This Dashcam? Stock 2011 - 2019 Ford Explorer Discussion 17
Daheim111 Amount of engine emission / where to find exact values ? Stock 2011 - 2019 Ford Explorer Discussion 2
D Where to buy paint? Stock 2011 - 2019 Ford Explorer Discussion 10
Daheim111 Oil / where comes it from ? (w. pictures) Stock 2011 - 2019 Ford Explorer Discussion 9
Z Where is the MyKey programming slot? Stock 2011 - 2019 Ford Explorer Discussion 3
W Giving credit where credit is due Stock 2011 - 2019 Ford Explorer Discussion 3
J Where are water drain holes in rocker panels for 2013 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 1
D Where is the brake controller cable / plug? Stock 2011 - 2019 Ford Explorer Discussion 21
D OEM or used body parts - where? Stock 2011 - 2019 Ford Explorer Discussion 4
C Where is fordservice???? Stock 2011 - 2019 Ford Explorer Discussion 2
P Anyone know of where to find a diagram of the 3.5L TT engine in the sport? Stock 2011 - 2019 Ford Explorer Discussion 2
F Media Hub lid broken. Where to buy parts? Stock 2011 - 2019 Ford Explorer Discussion 7
B Where is Auxillary line in on 2012 Explorer XLT? Stock 2011 - 2019 Ford Explorer Discussion 7
1 Where Did The Thread Go... Stock 2011 - 2019 Ford Explorer Discussion 2
H Key Fob - Where are the Receiver(s) located on the EX? Stock 2011 - 2019 Ford Explorer Discussion 10
I Air Intake - From Where? Stock 2011 - 2019 Ford Explorer Discussion 21
G Where to find replacement headlight dust/moisture caps? Stock 2011 - 2019 Ford Explorer Discussion 2
J Is The "Where Am I" Nav. Feature Totally Gone from MFT after Update ? Stock 2011 - 2019 Ford Explorer Discussion 11
T Where is the passenger radio volume control Stock 2011 - 2019 Ford Explorer Discussion 15
L Where do you bring your car to be serviced? Stock 2011 - 2019 Ford Explorer Discussion 15
S Where'd the TSB sticky go? Stock 2011 - 2019 Ford Explorer Discussion 1
S OK. Where is this mysterious fuse 29? Stock 2011 - 2019 Ford Explorer Discussion 3
S Where to find the Explorer owner's manual in pdf? Stock 2011 - 2019 Ford Explorer Discussion 15
J Where do you install a subwoofer? Stock 2011 - 2019 Ford Explorer Discussion 18
C Code Reader Stock 2011 - 2019 Ford Explorer Discussion 3
Daheim111 SD card reader / how to clean... Stock 2011 - 2019 Ford Explorer Discussion 4
Similar threads
