Where did you mount your antenna?
AlaskanJack
Elite Cabin-Fever Captain
Centralia, Washington
91 , 93 & 01 Sports
If you remove them you break the copper contact that is stuck to the window as I discovered when I checked them out. Nope thney are definitely not for remote start. A coaxial slips into them, but 3. That was not sounding right to me. It also has an external cell antenna that is attached to the rear quarter glass.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
ld50
Oh, the money you`ll blow
British Columbia
93 4 dr 4x4 manual XL.
:eek:
I thought it would be colder there! ;) You just in a tee shirt today?
So do you have like three coaxial connectors hanging down under you dash then?
Which leads me to ask the question: how do people hook up dual (or more) antennas to their cbs?
AlaskanJack
91 , 93 & 01 Sports
I don't know and it confused me as well how to hook up multiple antennas. No coaxial hanging down just the jack under the antenna it looks like what a stock radio antenna wire would hook into. Ya know with the jack and then it pressure fits into the hole. I'll get a pic tomorrow at work and that might do more.
Ray Hutchinson
Moderator Emeritus
Dana Point, CA
'93 XLT
Weird little antennas
Alaska,
Best bet, analog 800 mHz cell phone antennas. The previous owner probably used the Ex as a mobile office. In the early days of analog cell service, to avoid stiff roaming charges if you travelled a lot, folks got two separate cell phones, (or 3) if they moved through different cell co. service areas. It was more economical if you used a lot of time to do it this way. The 3rd antenna may have been for a mobile fax. Used to be you couldn't fax over regular cell phones, and you had to get a whole separate set up. You still see a few cars with 3 antennas on them around here. They just never removed them.
Crankcase
Moderator Emeritus
Moderator Emeritus
Vancouver B.C, Canada
1992 XL Ex-Police
Originally posted by ld50
:eek:
In big rigs, which have dual cb antennas, there is a splitter adapter that screws into the back of the CB, and seperates the jack into two seperate jacks....It can be bought at truckstops....
I have seen all sorts of weird antenna setups in Ex-police Explorers......Double ended radio jacks, flat cables, dual antennas.....Even my X had handfulls of wires I could literally pull out from under the dash.... :D :eek:
AlaskanJack
91 , 93 & 01 Sports
Well maybe it was for cell phone, but there are 3 of those on the inside of the glass and then there is the standard exterior glass mount larger cell antenna. I would have expected to find some additional wiring maybe. I am going to research this a little more.
mikeinpa
Clifton Heights, PA
91 Explorer XLT 2WD
Maybe the pieces sticking out horizontally are actually for a ground plane since they are attatched to glass and not metal? the vertical one would be the radiator ( part connected to the center conductor on the coax). If you look at antennas on roof tops there is a vertical element and smaller horizontal elements. Judging from the connector Im gonna guess cell phone or maybe police scanner.
AlaskanJack
91 , 93 & 01 Sports
Here is a pic of the two rear ones. I was wrong in my first explaination of them. There is a round piece sticking down, plastic. It appears as though something clips on to it. No plug in what so ever.
mikeinpa
Clifton Heights, PA
91 Explorer XLT 2WD
Judging from the pic it looks like each one of those have a connector on top? I see a little shadow in the center of each one that looke like a connector. A pic from outside (through the glass might be helpful). My guess is that the coax was run under the trim molding above the doors to the rear hatch and dropped into those boxes (cant remember the name for them) from above to avoid having them dangling from the bottom. I had a 2 meter ham antenna that looked similar but they can be made for just about any use...ham, cb, cell phone, scanner. Looking through the rear window from outside there should be a metal plate on each one. They are glued on with rear view mirror type adheasive to the inside and the othe piece gets glued to the outside (the part that radiated or recieves the signal).
Let me ask you this...What was your intended use for these? If you have the pieces that mount on the outside they can probably be used for just about any RECEIVE ONLY application. If you plan to transmit you need to have a antenna that was tuned (ie the right langth) for that application. If the outside pieces are missing then they are pretty much useless in my opinion, Unless Im totally wrong about what these things are :)
1 where did you install your cb?? Ham Radio - CB - Trail Communications 4
Perry Where did we get those CB's?? Ham Radio - CB - Trail Communications 4
N Where to mount an external speaker? Ham Radio - CB - Trail Communications 7
P where to mount? Ham Radio - CB - Trail Communications 9
N Where can I get through ? Ham Radio - CB - Trail Communications 4
N Where to mount my new "Icom IC-7000" ... Ham Radio - CB - Trail Communications 1
H where to mount Ham Radio - CB - Trail Communications 4
K Where/How to mount Fullsize CB/Linear in a 2nd Gen. ?? Ham Radio - CB - Trail Communications 2
9 Where to mount? Ham Radio - CB - Trail Communications 12
I Where to buy CBs? Ham Radio - CB - Trail Communications 13
M new to ham where to start? Ham Radio - CB - Trail Communications 3
J Where to mount an antenna? Ham Radio - CB - Trail Communications 9
E Just got My Ham License!!!!!!, where to mount ham rig Ham Radio - CB - Trail Communications 13
S GROUND(S) When, Where & How ? Ham Radio - CB - Trail Communications 1
S Where is the Computer? Ham Radio - CB - Trail Communications 2
J where to put a cb in my 2000 x??? Ham Radio - CB - Trail Communications 4
M CB Antenna - where to buy??? Ham Radio - CB - Trail Communications 4
4 antenna where Ham Radio - CB - Trail Communications 3
M where to buy CB accesories Ham Radio - CB - Trail Communications 8
P Where to Mount a CB? Ham Radio - CB - Trail Communications 55
K I need my CB/Firestick tuned - where do I go? Ham Radio - CB - Trail Communications 7
D Where to mount on '93? Ham Radio - CB - Trail Communications 6
F ?where to install CB? Ham Radio - CB - Trail Communications 9
S Antenna Mounting - Where / How / Performance ? Ham Radio - CB - Trail Communications 5
S Where to mount two 4' ers... Ham Radio - CB - Trail Communications 1
E Where to run antenna wire? Ham Radio - CB - Trail Communications 8
E Where to mount External Speaker? Ham Radio - CB - Trail Communications 2
S Where should I hook up the power wires for my CB Ham Radio - CB - Trail Communications 5
P Where do I mount my CB? Ham Radio - CB - Trail Communications 4
T where to run wires? Ham Radio - CB - Trail Communications 4
RangerX Where to get a CB antenna? Ham Radio - CB - Trail Communications 2
9 Where can I get this battery? Ham Radio - CB - Trail Communications 1
Z Did I kill my CB? Ham Radio - CB - Trail Communications 7
Brian1 1st and 2nd Gen A-Pillar NMO Antena Mount Ham Radio - CB - Trail Communications 0
R Mic mount inside 91-94 explorer or 89-94 ranger Ham Radio - CB - Trail Communications 2
bronchole I Need a HD NMO roof mount Ham Radio - CB - Trail Communications 4
soon2bsick will this cb mount location work? Ham Radio - CB - Trail Communications 40
R Pictures of my antenna mount as requested (not pretty) Ham Radio - CB - Trail Communications 4
T brake light antenna mount Ham Radio - CB - Trail Communications 19
ncranchero Wanted Good Used Remote Mount CB Ham Radio - CB - Trail Communications 0
N 102' whip mount Ham Radio - CB - Trail Communications 11
I Tail light antenna mount install Ham Radio - CB - Trail Communications 21
I Antenna stud mount with ring connector? How to connect to cable? Ham Radio - CB - Trail Communications 5
I Roof mount CB antenna? Ham Radio - CB - Trail Communications 12
BlackHawk09er Antenna mount Ham Radio - CB - Trail Communications 6
L HOW TO: ball mount for CB antenna installation Ham Radio - CB - Trail Communications 25
J midland glass mount antenna to any cb Ham Radio - CB - Trail Communications 2
A Wheres a good spot to mount a radio Ham Radio - CB - Trail Communications 17
S Firestik hard mount or Wilson magnet? Ham Radio - CB - Trail Communications 1
X mounting a lil willie antenna roof mount style Ham Radio - CB - Trail Communications 6
Similar threads
