where do the ground wires go? | Ford Explorer Forums - Serious Explorations
rydrew55
Connecticut
98 XLT
Hi All,
I am in the final stages of my 98 4.0L SOHC engine swap. Just buttoning everything up and attaching the front accessories. I'm stuck because I forgot how the ground wires go.
One of the first things I did when I pulled the motor, was disconnect the pcm and remove the hood. There are 2 ground wires and I can't remember how they go.
1. Short black ground wire that comes out of the pcm harness.
2. Long Braided ground strap attached to the passenge side head.
The reason I am confused is that the long ground strap has a stud with a double bolt on top. It looks like it would be used to hold down the pcm connector. The short pcm ground wire only has a term lug so it "appears" to be made to attach right near the pcm.
There is also a loose nut on the wiper mounting stud which has green (electrical) lok-tite on it, like it would accept the term lug.
PICS below
Seems the opposite of what it looks like.
Could I have mistakenly put the stud with the braided ground strap?
Does it really go with the short pcm wire harness instead?
Is there a regular bolt for the pcm mount bracket?
Does the braided ground strap mount on the wiper stud?
And finally, doesn't the hood have a ground wire?
I'm so confused!!!!!!! Can anyone help or post pictures....
Thanks
the pcm connector, to the right in the picture it should be 2 ground straps, a stun, then a bolt after to hold the pcm in place.
Thanks,
Streetrod also replied to my engine swap thread with some nice pics
