where is the AIT sensor???
rama1200
Jackson, MS
2004 explorer xls
I was trying to install one of those "computer chips" that modified your ecu input, bla, bla, bla to get more power (yes, yes, i know, i know.... call bama chips, call bama chips... BUT I'M BROKE!!!!)... anyway... install went ok but after the 1rst couple of runs the "check engine light" came on... I followed the "what went wrong" rescue sequence and the light went away for a while but it came right back...
i emailed the guy who sold the item and he said the only thing that he could think off is that i installed the chip to the wrong sensor...
the chip is supposed to "bridge" the input/output between the AIT sensor and the ECU.... well I thought the AIT sensor was the one right next to air intake "sucking end" .... am i wrong?
does anyone know where the AIT sensor is located for a 2001 x sport???
thanks.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
aldive
Elite In Memoriam
1999 XLT
I am nor familiar with the term AIT. Do you mean the intake air temperature sensor?
davidmmm69
Location
Fall river ma
2010 Ford Explorer V6 Fall River Ma...
2002 Mercury Mountaineer
i believe the air intake sensor..Or AIT as some call it.
Jefe
Clarksville, TN
'00 XLT 4x4
Yeah, I imagine he's talking about the IAT (intake air temp) sensor
The sensor just after the air filter is both the MAF (mass airflow) sensor and the IAT in one.
aldive
Elite In Memoriam
1999 XLT
That being the case, the IAT sensor on my '99 is built into the NAF, not sure about his.
rama1200
Jackson, MS
2004 explorer xls
Intake Air Temp Sensor... i guess i'm dislexic (or however you write it)
sorry about that...
Yes, it is the Intake Air Temp sensor... actually the manufacturer of the chip said that some cars have a "combo" sensor... I guess the IAT and MAF???
I called ford to ask this and they want to charge me some $$$ (ain't that something??? )
i checked carefully and the only sensor that i found was the one as described before... other than that, i think the nearest sensor in the intake line would be somewhere inside the engine where the intake pipe comes into??? i don't know
aldive
Elite In Memoriam
1999 XLT
rama1200 said:
4 or 5 can't remember...
It should either be 4 or 6. If you have 6, then the IAT is in the MAF.
aldive
Elite In Memoriam
1999 XLT
Maybe this will help you.
I will take a picture of the actual plug in a few minutes.
aldive
Elite In Memoriam
1999 XLT
As promised, here is a picture of an old 6 wire MAF plug.
BeauJ
Moderator Emeritus
The check engine light might be from your fuel running too lean or you o2's acting up. Could you tell a difference in power?
MONMIX
I fix dents
Staff member
Moderator
Millersville , Maryland
2000 Explorer Sport
you didnt get one of those e-bay special resistor type " chips " did you ?
aldive
Elite In Memoriam
1999 XLT
I do believe that is what he has.
rama1200
Jackson, MS
2004 explorer xls
sure did... if you were standing at a red light and tried to punch it hard, the torque/hp was none existing, it took for ever to get to 2500 rpm and/or 40 mph, but the after that, there was a little kick and rpm rev'd up quick... shifting was al a mess, too.
rama1200
Jackson, MS
2004 explorer xls
don't know since i'm not electronics expert, but i think i know what you are talking about... probable yes, since it was cheap (about $30.00)...
i saw what they had on ebay, and i thought i should have gone with one of those $5.99 ones... if results were going to be the same.
davidmmm69
Location
Fall river ma
rama1200 said:
yup... just like that... that was a nice schematic drawing where did you find it??
He has everything lol
aldive
Elite In Memoriam
1999 XLT
You can't make chicken salad out of chicken s***, no matter how much mayonnaise you use.
E 01 2wd 5.0 performance upgrades... where to begin. Modified 1995-2001 Explorers 10
bronchole Where to put a secondary transmission cooler? Modified 1995-2001 Explorers 16
M 96 5.0 tuning? where how who Modified 1995-2001 Explorers 35
M Where is the day\night automatic sensor? Modified 1995-2001 Explorers 9
1 1998 5.0 fuel pressure regulator. Where is it? Modified 1995-2001 Explorers 1
D Where to start? Modified 1995-2001 Explorers 0
M I want a 2nd fuel tank underneath where the spare tire goes Modified 1995-2001 Explorers 1
A Where to attach if I want to splice into auto headlights? Modified 1995-2001 Explorers 1
S Where is my Starter Solenoid, 2000 Explorer Modified 1995-2001 Explorers 3
D Where to put the wires? Overhead Off-Road Lights Modified 1995-2001 Explorers 7
B Where the heck do i find a 3 inch body lift for my 2000 eddie bauer Modified 1995-2001 Explorers 6
9 Where can I find these.. Modified 1995-2001 Explorers 4
B Where to get new body mount hardware?? Modified 1995-2001 Explorers 2
1 where do you guys run your wires for roof lights? Modified 1995-2001 Explorers 8
C time to upgrade but where to start Modified 1995-2001 Explorers 3
S Where to find intake tubing? Modified 1995-2001 Explorers 0
bronchole Where do I get a 7 tooth drive gear for a 4406? Modified 1995-2001 Explorers 12
B Front licence plate holder... where can I get one? Modified 1995-2001 Explorers 9
B Not sure where to post this, my situation... Modified 1995-2001 Explorers 1
K Where to buy a underdrive waterpump pully, and overdrive alternator pully? Modified 1995-2001 Explorers 2
M Where do I start Modified 1995-2001 Explorers 2
T Where to get the sunroof cover? Modified 1995-2001 Explorers 0
C Where Can I find longer front Shocks Modified 1995-2001 Explorers 2
X Where to find Lift Spindles?? Modified 1995-2001 Explorers 9
U Viper 5701 Flex relay...Where do I wire it? Modified 1995-2001 Explorers 0
T Where do I start with my 2000 XLT? Modified 1995-2001 Explorers 6
D Where to get a good cam fr 5.0 engine? Modified 1995-2001 Explorers 12
sean99 where is the shift point at wot?? Modified 1995-2001 Explorers 4
B where can i find a cheap suspension lift Modified 1995-2001 Explorers 9
D where do i get aftermarket mods! Modified 1995-2001 Explorers 8
S Interior Lighting, Where can i patch in??? Modified 1995-2001 Explorers 2
J Wanted any 1 know where a rear saleen bumper z ?? Modified 1995-2001 Explorers 1
F Where Can I Get a Custom Fab Bumper For a 97 Explorer Modified 1995-2001 Explorers 20
G Where to Find Rear Pillar Post Modified 1995-2001 Explorers 1
E Where to purchase LED interior lights? Modified 1995-2001 Explorers 4
T where to go or who to talk to for backspacing and rims sizes Modified 1995-2001 Explorers 2
4 where to go now? Modified 1995-2001 Explorers 3
local7teener Coilover swap done.. Need stainless brake lines. WHERE DO I GET THEM?? Modified 1995-2001 Explorers 4
S No fuel Pressure. Where do I go from here? Modified 1995-2001 Explorers 10
L Where to buy Warrior Shackles Modified 1995-2001 Explorers 48
R Where are the ignition wires? Modified 1995-2001 Explorers 6
C Need 1.5 Shackles (Where can i find cheapest) Modified 1995-2001 Explorers 10
P finaly got her near where i want her Modified 1995-2001 Explorers 6
S gear code. where? Modified 1995-2001 Explorers 7
X Where to buy Shackles up north? Modified 1995-2001 Explorers 2
parad1mg VSS Signal tap where? Modified 1995-2001 Explorers 21
T Where to get a good deal on stock 8.8 perches Modified 1995-2001 Explorers 6
T i found where a cowl induction hood for 95-01 explorers!!!! Modified 1995-2001 Explorers 8
D Custom Rims (Where do you get them?) Modified 1995-2001 Explorers 6
P where to buy 4'' superlift Modified 1995-2001 Explorers 5
Similar threads
