cleansho93
- October 2, 2010
- Saint Louis, MO
- 98 Eddie Bauer 5.0L
Hello I am new to these forums and really need some help. I have a 98 eddie bauer explorer with the 5.0L and ARC. I had it in the shop the other day for inspection and since then the ARC compressor is not working. The mechanic turned off the system before putting the truck on the lift, turned it back on afterword. Since then the compressor has not ran and I basically have no shocks. I checked the fuses in the main distribution block under hood relating to ARC and they are fine. I have read that there is a separate ARC relay located somewhere other than the main distribution box but cannot locate it. I found the aux relay box located below the air cleaner under hood and it houses 4 relays without labels. I cannot find any info on the purpose of these relays in the owners manual or online. Can anyone tell me which one of these is for the ARC or where the ARC relay is located otherwise? Thanks in advance for any help, really need to get this working.
