Where is the warning chimes located on a 2004 ST XLT? | Ford Explorer Forums - Serious Explorations
KajunBndit
Theriot, LA
2004ExplorerSportTrac XLT
Hello everyone, I have looked through the forum and searched the internet till I can't see straight. LoLoLoL. My headlight warning chime and the key in the ignition engine off, driver door open warning chime doesn't come on. I would like to enable them. If someone can tell me where they are located, It would be appreciated. Later down the road, I would like to put factory drive/fog lights in the front. Would anyone know if the wiring is there already and the light housing? I know I would have to cut the holes in the front bumper, no biggie there. Any replies are welcome. Thank you.
no clue on the chime. as for factory fogs.... i have an 05 and 04-05 have the fog switch built into the factory headlight switch. you pull the knob outward to engage the fogs. mine did not come with factory fogs and no factory wiring/fuses are installed. on ebay they sell the factory housings for about 40-50 USD the last i checked they install like factory. for wiring i would tap an accessory wire and a relay to engage the lights nice part of this is anytime the key is in accessory or run the lights work high beam cut off is no issue this way
Thank you.
