where the ground be | Ford Explorer Forums - Serious Explorations
where the ground be
sauk rapids mn
99 sport 2dr 4.0
im tryin to put my system back in my sport and cant find a decent spot to ground my amp. i will be putting in 2 12 rockford p12s on an older 1500 amp also does anybody make a box that would hide these in the factory plastic:salute:
i found a nice bolt on the middle sealbelt assembly. Its not the one on the top, but the one on the bottom on the right side of the seatbelt (looking towards front of car)
run the wire through the floor and ground to the frame itself.
i used a bolt from one of the rear seat mounts. close location and no drilling required
Same hear, seat mount bolt, works great. If you have to sand it a bit do it. Just use some silicon caulk
you can always run it all the way back up to the battery too...thats the best possible method
