parris001
- April 6, 2013
- Franklin, TN
- 1994 Explorer XLT
First off, this forum is great in helping me keep my old Explorer up and running. It's a great truck, been through three generations of my family, and I can't just give up on her.
Wednesday I was going to work and I started getting smoke out of my vents. You know the drill, smelled like someone's wood burning stove. I panicked and pulled over and popped the hood. Nothing under there. Nothing at all. So I closed her back up and started home. Figured I'd get there because I wasn't that far away. On my trip back to the house the smoke started rolling and the smell turned very much plastic. I pulled over again and raised the hood and this time saw the fire. It was coming from down below. Between the fan motor and evaporator housing. I had a half gallon of antifreeze in the back of the truck. I snatched my battery ground off (I never keep these things tight) and doused the fire with the antifreeze. Once I knew it was out I pulled the fuse and relay for the blower motor and actually continued back to work.
My question is: it melted my evaporator housing pretty good. How hard is it to pull that half of the housing off to possibly patch it? I was considering doing a little sheetmetal or aluminum patch panel repair. But I may just pull the housing off and 'glass it.
