Where this hose plug?? | Ford Explorer Forums - Serious Explorations
X-North
Montreal
I have a 1992 Explorer 4.0 OHV 4X4. I removed all the A/C so maybe its use for something of th A/C i dont know.
I just looked at my vacuum line and seen that ...where does it go ??
Also theres a plastic thing like a "submarine" just beside the blower motor assembly...can someone send me a picture of this to see if i plugged it back correctly?? Thank you
there should be a t that it plugs into. it goes to that sub thingy an the heater control valve at the heater core.
The submarine thing is a vacuum reservoir for the A/C system. The line in your hand Probably goes to supply this. This line and reservoir provides vacuum to control the outside/recirculate air door in the dash. The tube in your hand should plug into a small check valve near the resrvoir.
This is the best I can do from your pic.
Good luck
