Where to ground | Ford Explorer Forums
Where to ground
iHartsuff
Memphis, TN
'94 Explorer Sport
I'm in the process of installing subs in my 1994 explorer.
Does anyone have a diagram or something with the places I can ground in the trunk of my car?
I just need to know where I can ground.
you can ground it anywhere, lol. The body is grounded to the battery. I drilled a hole in the floor and put a firewall grommet thing in, and ran 1/0 to the frame, with a lug on end inside the truck. That way I have a spot to ground things. But pretty much any bolt, just scrape off the paint so it gets good contact.
I took out the rear seat in my sport and put the ground on the stud that to seat bolted on too.. and bolted the seat on top of the ground so you know that there will be metal contacting it... but thats how I did it.
You know the little hooks that the cargo net hooks onto? I put a ring terminal on the end of my ground, unbolted one of those, and then rebolted it down with the ring terminal between the body of the Exploer (paint scratched off underneath) and the hook. Has worked fine for near 4 years now with 3 different amps/sub combos.
