I was just wondering where you guys put your ps2's in your vehicle? I was going to put it under my backseat but then i decided i didnt want to. I just wondered where everyone else mounted theres and maybe some pictures showing where.
Good question. I was wondering the same thing. Only I have an XBox. I figured I could put it in the rear cargo area on the side, standing up, but I am not sure if it will still work with it on a 90 degree angle. Another place would be on the foot rest of the front passenger area on a 45 degree angle. I am just throwing ideas here, I'm not sure if this will actually work.
mine is currently mounted in my center console as it awaits completion. if you don't have or remove teh 6 cd changer it will fit right in the place of the changer with a little dremel tool work. make sure to cut a hole in the bottom plastic so the ps2s fan can actually draw air as well. also- you need to trim the armrest piece too a little in order to make it work but only where its not visible. i was able to trim it enough on the underside that the controllers fit right next to the unit as well and everything is completely hidden in there. it is the ideal place for the ps2.
as for mounting the x box verically- don't do it it won't function properly for long that way
the xbox has to be flat otherwise it wont run.... but the ps2 can go almost anywhere its very slim make sure they dont get to hot though that wears on them
