Where to order long Trans Line for 6R60? | Ford Explorer - Ford Ranger Forums - Serious Explorations
BigBlockWagon
Location
Massachusetts
South Hadley, Massachusetts
2007 Sport Trac Limited
Hi,
I need to order the long Transmission Line for 6R60? It is the line that runs from the cooler in the radiator all the way back to the side if the transmission. I have located the radiator cooler line to the auxiliary cooler on Rockauto.com.
Any suggestions where to get this line? I really only need the end that goes into the radiator due to rust.
Thanks
BigBlockWagon
Location
Massachusetts
radiator cooler to transmission line for 6R60
I found the correct line at Ford for $97.65 full p/n 6L2Z-7R081-B
Also needed is 4 o-rings p/n 6L2Z-7J227-A this is where both lines bolt to the 6R60 trans.
Even though I didn't get a single reply I'm hoping this will help someone in the future. Please note the build date on your ST
Here is the info copied from parts.ford.com
Tube Assy
Part #: 7R081
FORD PARTS
Transmission Cooling Systems
Usage: 01/30/2006 - 08/07/2006, Explorer Sport Trac, 6 Speed Auto Transmission 6R60
Happy Sport Trac'ing
Levittown, NY
All
Tube Assy
Part #: 7R081
FORD PARTS
We can help with a little better pricing if you have not ordered yet Tube - Ford (6L2Z-7R081-B) | Ford Auto Parts
Let me know,
Benny
