briwayjones
Manual Master
- December 11, 2003
- Location
- Maryland, USA
- Eldersburg, MD
- 2000 Ford Explorer XLS
Best place to get power?
I have a stock CD/Tape player in my X and got a Auxilary Input converter so that I can also hook up my MiniDisc head unit to it. It lets you hook up devices through RCA inputs. The thing is I still need to power the second headunit. Were would be the best place to tap into power for it? The power on the stock HU harness? If I did that would it provide enough power to both of them without hurting them? Also when I tap into another wire, instead of splicing all three wires together by using a wire nut or soldering them together is there a way to hook them together so that just one or more of the wires could be easily seperated and then put back together? You know the flat post connector things that you slide into the little things on the other end of the wire (sorry for using technical terms here ) do they make three way versions of those? Thanks
