Where to wire aftermarket heated seats | Ford Explorer Forums - Serious Explorations
tojan19
Smithfield VA
06 EB
I've got a pair of aftermarket heated seat pads I'm going to put in my 06. The kit didn't come with relays, just direct wiring. I do have spare relays I can use if necessary. What's the best/most convenient place to get power? Interior fuse box?, EC fuse box?
What is the amperage that they require?
I WOULD wire in a relay to the battery and then also to the ignition harness. I say this due to the newer ex's dont have hi-current ignition harnesses. If you relay it in to the ignition wire then they will shut off with the ex then you turn them off. Remember to fuse the battery lead.
