Where? | Ford Explorer Forums - Serious Explorations
Where?
ChiTownXsport
Chicago
'01 Xsport
Where did you all put your ground for your amps..... i just put in a infinity amp, but cant get a good ground anywhere everytime i turn the volume up past about 1/4th the way up it goes into protect... im runnin 2 audiobahn 12's.... So where did you all ground your amp?
Right under the rear cargo carpet on the metal piece right there. Pushes 1K fine for me, amp has never thrown itself into protect.
well i just bought a rockford grounding block so hopefully this will fix it.... my amp is only 700 watts... im going to upgrade the ground wire to 4 gauge to so hopefully that will help.
