SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
I'm getting ready to change the leaking gasket on my oil filter adapter and I understand that since coolant runs through it to help cool the oil that you should drain the coolant prior to removing the adapter. Apparently, this will help avoid creating a mess of oil and coolant on the garage floor.
Since my vehicle has 130K+ miles on it and I've never changed the coolant out (dumb, dumb, dumb) I figure now's a good time to do it. I consulted my Owner's Guide and it says the coolant for my vehicle is Motorcraft Premium Engine Coolant (green-colored) or Motorcraft Premium Gold Engine Coolant (yellow-colored). So I looked under the hood and the reservoir has a sticker on it that depicts a "NO GOLD COLOR COOLANT" image on it and sure enough the reservoir contains a green colored coolant. Okay...I'm convinced that gold coolant is not the way to go. However, what the heck is the green coolant I'm supposed to put in there? Do I literally need to pay the big bucks for Motorcraft brand coolant?
Last time I went through this was on the girlfriends SUV that used DexCool (orange-colored) but since I changed out her radiator I flushed it and switched to universal coolant which apparently was also green. I do not plan on doing a "complete flush" like I did on her SUV so I just need to figure out was is the correct and compatible coolant for my Explorer so I don't eff things up.
You those of you who had Motorcraft Premium Engine Coolant GREEN in your Explorer what did you end up purchasing when you replaced your coolant?
Just in case anyone is wondering about the three major types of coolant that Ford uses they are:
* Yellow-colored Motorcraft Premium Gold Engine Coolant, meeting Ford specification WSS-M97B51-A1
* Green-colored Motorcraft Premium Engine Coolant, meeting Ford specification ESE-M97B44-A
* Orange-colored Motorcraft Specialty Orange Engine Coolant, meeting Ford specification WSS-M97B44-D
Ford's "green" product is called "VC-5 Premium Concentrated Antifreeze/Coolant". I guess the question is: Who makes a coolant meeting Ford specification ESE-M97B44-A that isn't going to drain my wallet?
Maybe this is the answer I'm looking for from Prestone's website:
Prestone® Antifreeze/Coolant meets or exceeds the performance requirements of the following specifications:
ASTM D3306
SAE J1034
GM 1825M
Ford ESE M97B44-A
Chrysler MS7170
General Services Administration CID A-A-52624
ASTM D3306
SAE J1034
GM 1825M
Ford ESE M97B44-A
Chrysler MS7170
