which locker
redrocket1468
greenville
93 limited 4in.sus3in.bod
have 4.56 gears now and looking for a locker for the front dana 35. was wondering what i should get ive been looking at the richmond lock right and the aussie locker
LBarr2002
Leesville, SC
'91 XLT 4x4, '92 XLT 4x4
Aussie!!!
Lee Iaccoca
Washington, DC metro-area
1991 Explorer EB
I have been using an Aussie in the Dana30 on my Jeep YJ Wrangler for more than two years. This locker is invisible in 2wd and of course provides great traction in 4wd. No noise in 4wd either
I'm in the southwest U.S. and we don't get much weather here (Need to update my profile)
Opinions vary on the safety of having an autolocker -- such as the Aussie -- in your front end if you are ever in snow or icey conditions w/4WD engaged. Some say you get used to driving with it in those conditions. Others say avoid installing it altogether. Still others say stay in 2WD until you get stuck :D.
HahnsB2
Battle Ground WA
88 Bronco II
Aussie!
redrocket1468
greenville
does the aussie make alot of noise in yours i have noticed that some say theres is quiet and some say its noisey
HahnsB2
Battle Ground WA
88 Bronco II
Never heard a peep out of mine in the front, my rear lock-right is quiet too.
LBarr2002
Leesville, SC
You can hear mine ratcheting if you're not in 4wd but have the hubs locked and make a sharp turn. Other than that I never hear it.
alohamonte
Glendale, AZ
1998 Explorer 4.0 4x4
locker
redrocket, is your rear open, l/s, or locked?
redrocket1468
greenville
its LS in rear
mjones97
Salem, IN
Either Aussie or a Detroit EZ-Locker. I have the EZ-Locker in my Dana 35 and the ONLY time it makes a noise is when the front is locked in and making a real sharp turn. I love having both front tires locked together.
Mickelsons
Boring, Oregon
'91 explorer
What about ARB? Any input about them?
HahnsB2
Battle Ground WA
88 Bronco II
What about them? Selectable, drives normal on the street, expensive, requires on board air and many more parts to go wrong. To me a selectable isn't worth the price, I don't mind how autolockers handle and I like being able to stomp it and put power down through both tires instead of spinning one, the only selectable LS/locker combo is the Aurburn ECTED but it is not a true locker, the clutches only get tighter, there is no positive locking mechanism and they are known to slip.
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
After watching Ted (Tbars) and listening to him over the CB as people took him through the ditches with his front locker at truckhaven I decided a full auto locker wasn't for me.
We can't afford an ARB so I got Ranger X's Trac-loc (limited slip).. I'm going to put an extra clutch disc in it when rebuilding it to make it tighter but it still won't be a full locker..
Most of the trails I go on need the ability to make sharp turns which doesn't normally happen with a front automatic locker.
I don't want to have to keep hopping out of the truck to unlock a hub or keep doing multi point turns becuase the front wants to go straight.
~Mark
redrocket1468
greenville
from what i have read on the auto locker when your turning it ratchets to let one wheel spin more so you shouldnt have a problem
FROADER
Staff member
Moderator
Huntington Beach, CA
1991 Eddie
Absolutely love my TrueTrac L/S in the front of mine. :)
I know...
I say that a lot.
But from your choices I would go with the Aussie. I have heard nothing but good things about them.
Maniak
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
Only when your not on the gas.. When your on the gas it doesn't ratchet.. the ground slips before the lockers lets the wheel spin..
~Mark
Nedwreck
Kentucky, Y'all!
'93 xlt, '92 4x4
~Mark
will a rear aussie-type locker act this way on the road?
HahnsB2
Battle Ground WA
88 Bronco II
Personally, I'd rather have to add a couple steps for a sharp turn than not have a locked front when I need it as most people with locked front ends feel. It really doesn't lessen your turning radius that much, but then again I have a shorter wheelbase than you X guys.
Yes, in long fast sweeping corners you'll never notice it, use light positive throttle on sharp corners so it can unlock, it's not as bad as it sounds, I daily drive almost 1000 miles a month with a locked rear and wouldn't trade it for anything, I purposely make it lock around some sharp corners as well, most of the time the tires wont chirp and I haven't noticed any extra tire wear out back.
Maniak
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
On the road your in 2wd.. so the locker in the front wont' do anything UNLESS the hubs are locked.. which your normally don't do..
If the locker was in the rear then yes.. the auto rear locker can give you locker wiggle on the road..
~Mark
Nedwreck
Kentucky, Y'all!
'93 xlt, '92 4x4
~Mark
Yes that was the Q&A. Rear lockers. Aussie's website talks like theirs ratchets better, allowing the outside wheel to overspeed away from the other wheel in a turn.
You indicated lack of ratchet action while in the dirt and on the gas. I was checking on a rear locker on the road... and still wonder how it'd be under moderate acceleration in the curves. I got ya in an apple to oranges question.. sorry!
Sounds like wheel slippage for sure in snow (not that I'd be hard on the gas anyway).
Rainy roads might be that fine line that gets a fella in trouble, with an Aussie in the rear diff??
Wiggles from spools and such i get. Well, welded spiders anyway... from the hot rod days. I sure was a cheap b*st*rd back then. heh
