sholzee
- September 14, 1999
- Buffalo N.Y.
- 92 EB 4dr 4x4
I want to replace my RA bushings, Which do I get?? Ford wants $40 for a kit that does the front side of bracket, Then $10 each for the back of bracket and has a nylon sleeve or something. I see some at NAPA that have different degrees of caster they can adjust to. If I do the remove the rivets and bracket how much will alignment be affected. Things are pretty rusty under there I doubt an alignment shop will want to mess with it without charging a fortune.
