ToughCountry
- May 7, 2003
- Hopewell Junction NY
- 97 Explorer Sport
Hey guys i wanna change around my system setup a little bit b/c i am starting to get very unhappy with it. I have a Kenwood 600 max amp (2 channel bridgeable) and 2 12 inch JBL Gts. I was happy with them for awhile but i do not think that my amp has enough power to fully power both subs, but they are old and i would just like to get rid of them anyway. So since my amp is fairly new id rather keep that and maybe get a single 10 inch sub. I have a few in mind that i will list for u and if any gurus know which sub will be the best with my amp id appreciate it if u could let me know. thanx
- Infinity Kappa 100.3se 10" 4-ohm Component Subwoofer
Ceramic Metal Matrix Diaphragm woofer • rubber surround • 50-275W RMS power range • 20-250 Hz frequency response
- Infinity Kappa 100.3dvc 10" 4-ohm Dual Voice Coil Component Sub
Dual 4-ohm voice coils • Ceramic Metal Matrix Diaphragm woofer • rubber surround • up to 275W RMS total power • 20-250 Hz frequency response
- Rockford Fosgate Punch Stage 2 10" 4-ohm Component Subwoofer
Polypropylene cone • foam surround • 50-200W RMS power range • 20-200 Hz frequency response
- Infinity Perfect 10.1d 10" Dual 4-ohm Component Subwoofer
Dual 4-ohm voice coils • aluminum cone • high-roll rubber surround • 75-350W RMS power range (175W per voice coil) • 18-200 Hz frequency response
- Infinity Perfect 10.1 10" 4-ohm Component Subwoofer
Aluminum cone • high-roll rubber surround • 75-350W RMS power range • 18-200 Hz frequency response
- Audiobahn AW1000Q 10" Dual 4-ohm Voice Coil Component Sub
Dual voice coils • non-pressed pulp cone • foam surround • 50-600W RMS total power range • 23-500 Hz frequency response
- MTX Thunder 5500 T5510-04 10" 4-ohm Component Subwoofer
Mica-filled polypropylene cone • rubber surround • 150-300W RMS power range • 35-150 Hz frequency response
