Which trany do I have in a 02 explorer 4x4 | Ford Explorer - Ford Ranger Forums - Serious Explorations
bcv021
Bowling green Ohio
2002 xlt
Which trany and is there a band adjustment.4.0L Thanks
bcv021
Bowling green Ohio
2002 xlt
Anyone Know??????
Please
Bloomington, Minnesota
2005 Mercury Mountaineer
These 2002 to 2005’s have the “5R55_” 5 speed transmissions in them .
They are sealed .they do not have a dipstick.
They are sensitive to old (greater than 4 years and or 60,000) used up fluid.
And run fantastic on new Motorcraft Mercon five fluid.
Have the Ford / Merc dealer do a flush and fresh fill. Then you get the good stuff.
They absolutely require a semi synthetic transmission fluid meeting the Mercon V (FIVE) spec.
If plain old Mercon is used the transmission with function very poorly and may self destruct.
They are controlled electronically by a computer utilizing a very complex 32 bit computer code
As far a bands go … I don’t think you can or would want to adjust the Bands if they are even there.
You should ask a transmission shop or a ford or Mercury dealer.
Transmissions can be purchased at Rock Auto for about $1500 and you can get a discount code ( found at the Taurus Forum) for a 5% discount.
Look on the driver’s side door jam info sticker and look under the trans part to match the code to the transmission you have. R code = 5R55W , D code = 5R55E and V code = 5R55S they differ only by the 2 gear ratio.
Transmission Codes
Code Model
D (1997-2005) A5LDE / 5R44/55E
D (1992-1996) M5OD-R1
J M5OD-R1
J (2002 - 2003) R1HD / M5OD-R4
M (2000-2001) Mazda M5D4
M (1997-1999) M5OD-R2
M (1992-1996) M5OD-R1
R (2002) 5R55W
T (1992-1995) A4LD
T (1996-2001) 4R55E
U 4R70W
V 5R55S
X 6R60
Code Trans Code ( 1_ 2_ 3_ 4_ 5 Gear ratio)
D- 5R55E (2.47_1.87_1.47_1.0_0.75)
Jaguar Trans 5R55N (3.25_2.44_1.55_1.0_0.75)
V- 5R55S (3.22_2.29_1.55_1.0_0.75) = Lincoln LS and 4.0 Mustang
R 5R55W (3.22_2.41_1.55_1.0_0.75)
Axle Codes
L - Limited Slip Differential
C - Conventional Differential
Code Ratio
41 3.27C
42 4.10C
43 3.08C
45 3.55C
46 3.73C
D1 3.27L
D2 4.10L
D4 3.73L
D5 3.55L
bcv021
Bowling green Ohio
2002 xlt
band spec
What did you do to lesson the shudder. What spec did you set it at!!!
skeeter123
2002 XLT 4.6L
Did you find out which transmission you have? Assuming it's an 5R55, check out page 51of this doc:
http://www.ratiotek.com/5r55w-complete.pdf
I'd download the whole file while it's still free....
Per Brooklynbay post:
The procedure for adjusting the bands is as follows:
Loosen the nut on the adjusting stud while holding the stud in place. Set your torque wrench to 10 ft.-lbs. (120 in.-lbs.), and tighten the stud. When it reaches 10 ft.-lbs. refer to the above specifications to set the proper amount of turns back. Hold the stud in place, and lock the nut to 35-45 ft.-lbs.
The 5R55's are to back out 2 turns.
That said... note I'm no expert.... not to highjack ur thread but... Hopefully BrooklynBay et. al. could help out with this:
My 2002 XLT 4.6L 5R55W with 150K miles on has a shudder/stumble when accelerating normally through 45-50 mph. I had ATF changed at 98K (dealer) and 147K (DIY). It's had this shudder for years, lately its been getting somewhat worse. Doesn't happen under heavy acceleration, if I play with the gas pedal I can avoid it; but it always happens when accelerating "normally" through 45-50mph. I thought it was OD band, adjusted it per the procedure, noticed that it was quite loose, meaning that after torqueing it to 120in/lbs and backing out 2 turns, it was significantly more "in" than when I started (guessing at least 1 1/2 turns). Now here's the question: Is it normal for the "adjusting screw" to be really loose after backing out 2 turns? When I torque it down to 120in/lbs, its obviously tight, but when I go to back it out it feels really loose after only 1/2 to 3/4 turns. Does this mean that the OD band material is really worn off? I've considered trying it backed out only 1/2, 3/4, or 1 full turn, is that a good idea? I don't want to break anything. Adjusting it to 2 turns did help, but didn't completely eliminate the shudder.
I also had the PCM software updated recently, didn't help this problem. Would replacing the solenoid pack address this problem? Any response would be greatly appreciated.
