Which wiring harness to use | Ford Explorer Forums - Serious Explorations
flyanbrian
06' EB
I have an 06 Eddie Bauer that had the factory 6disc changer with the factory sub. No sync in truck either. And I'm installing a kenwood radio. I'm having an issue with the PAC c2r-frd1 harness. When I drive along the radio turns off after 10 or so minutes of playing and will not come back on. I originally sent stereo back and got new one but having same issue. Has anyone else ran that harness and had a similar issue?
Apparently I have the right harness but the guys at PAC are telling me I need to add a SPDT relay to the setup because some stereos pull more power.
quick note, helps to have a multi meter. tested the access wire(red) and did not have output to stereo. ordering a new wiring harness
new harness was the trick, I also installed a relay with it per notes from talking to customer support at PAC who make the wiring harness.
