Which would you choose? | Ford Explorer Forums - Serious Explorations
I know a lot of us use different brands of oils but of the two listed which would you choose?
  • Total voters
    20
  • Poll closed .
RickyG
Texas
2020 Explorer Limited
Callsign
I
Mobil 1 or Motorcraft?
I use the recommended regular Super Premium Motor Oil. The same as in my 2011 Limited, 2014 MKT and 2017 Platinum.
My owner's manual recommends Motorcraft synthetic blend 5w 30 is that what you're talking about?
No. If you check the recommendation for the Canadian market you will see what I mentioned.
Mobile 1 over the blend. Walmart full synthetic over the blend.
So you would fall under neither I use a different brand
I was sure I checked that off yesterday.
I didn't see your name anywhere as of today
I checked the box again right after my post yesterday. Looking at again now, it seems I forgot to click on Cast Vote.:oops:
We usually run Royal Purple or Brad Penn at the shop. But if I had to choose between these two I'd go for Mobil 1 full synthetic.
I'd say it is far more important to stick to the schedule and actually change it rather than worry about the brand (it still matters though, just not as much).
