Whining noise problem | Ford Explorer - Ford Ranger Forums - Serious Explorations
andrewlcarson
Olive Branch, Mississippi
1997 5.0 Eddie Bauer
I have had a 95 explorer for about a month now and everything is fixed on it except for this whining sound. It only occurs while driving but when you let off the gas the noise will go away. The whine is more loud at some speeds than others which really throws me off. I have put some transmission fluid along with some sea foam stuff from auto zone for transmissions in to see if that would do anything but of course it did not. I am just wondering if anyone has an idea what wrong or if this has happened to someone else.
Snowboi
Northwest, FL
1999 XLS
I'm having the same problem, but its when the RPMs are about 1k-1500, over 25mph, let off the gas, its gone. I'm thinking it would have to be something within the engine or trans, because once you let off the gas, its gone, but once you get back on it, it comes back. Soon, I'll be changing both the trans fluid and rear end fluid, rear end will be synthetic, the trans will be the same type of fluid.
andrewlcarson
Well let me know how things go because the noise to me is getting much worse and I have changed my transmission oil and nothing.
andrewlcarson
I do believe it is my rear end. Any hope on a fix or am I screwed?
jevchance
Grand Rapids, MI
2000 Mountaineer 5.0
Have the gear oil changed, or do it yourself. Its not too expensive, probably about $50 to have it done at a quick lube. Then you'll know.
You'll want to check if you have traction-lok before changing it though. You need to get your axle code from the sticker in your driver's door jamb.
andrewlcarson
Alright thanks. Ill get it done and see how it goes.
