nleipziger
- August 19, 2006
- Langhorne, PA
- 2006 Eddie Bauer
Hello all, have a 2006 Exp V6 with 200,000 miles on the odo. In cold weather during a cold start there is a loud whining noise from under the front of the vehicle. I replaced the belt tensioner and idler pulley because it's that type of noise it makes. Also replaced the alternator because using a scope, it appeared the noise was coming from there. The noise goes away after about 5 minutes. Now I'm suspecting possibly the transmission (front pump) might be causing the problem. Is this a possibility? Anyone run into this issue? Other than that, the SUV runs flawlessly and the engine and tranny have never needed anything. Thanks for your help....
