2004exlporer4.0
- December 3, 2015
- 2004 explorer k vin 4.0
I recently swapped a 2004 SOHC for a 1998 SOHC. The 2004 motor blew up from the previous owner and the best block i could find was out of a 1998.
When accelerating i am hearing a whirring noise coming from what sounds to be the front of a 2WD truck. I know that there are a few possibilities as to what the problem is since i only hear the noise when i get past 15mph and it does it during both acceleration and deceleration. The whirring noise is similar to that of driving over a grated bridge or if i were to have knobby tires on, which i do not.
I believe that the transmission is about 2 quarts low on fluid. I will be taking it to get a fluid change tomorrow since i do not have access to a pump.
Is the whirring noise possibly because the 98 SOHC used a different transmission than the 2004? Please note that when doing the swap i put the 2004's flexplate on to the 98's block.
Is it a bad wheel bearing?
Brakes?
Thanks in advance!
Brakes?
Thanks in advance!
