Just a short opinion...I have a 1991 Navajo w/AOD w/the Granatelli MAf.. I installed it 2 1/2 yrs ago & regardless of what some have said, I DID feel an improvement in both power, throttle response & very MINOR mpg gain. I have since installed Magnecor wires, Throttle body spacer & K&N filter.
On a freeway trip, 1300 miles, from San Diego to Spokane just last month, pulling a 4x8 U-Haul trailer & loaded w/just over 1000lbs of stuff, I averaged 15-18mpg the entire trip, including through the mtns, @ an avg speed of 70-75 the entire way. There was improved power going up the hills, in fact often my tranny did not even drop out of overdrive w/torque converter lockup on many of the moderate hills.
My vehilcle has 154,000 miles, has never had any work done on the engine or tranny & is a 4x4 model.
Just thought I'd pass on my info. And no, I don't work for any of the manufacturers of these products...I just feel that if there is a good product out there, you should pass on the info.
BTW, I tried out the Jacobs Mileage Master ignition setup. Truck ran worse, mileage dropped, very poor starting after hot shutdown...sorry, maybe some have had good luck, but I personally didn't.
