smegun
- April 3, 2013
- florida
- 1994 ford explorer xlt
tried a few different auto hubs but kept breaking the spindles inside the hubs
.... untill i changed out my universal joints ( bfh)on the front axels there was too much pressure on the hubs they were snapping the hub cam spindle that holds the sprocket
you can take out the hum sprocket /cam via the small snap ring down by the bearing but to the most part the nylon washer that holds the wave spring on these guys is a little toasted on most of these also and time for rebuilding
i read in some post that someone does rebuild these but wondering if its possible to rebuild them when the posts are snapped off at the base ???
id like a working set of autos for cruising switching to manual is no problem
hard to find those mod washers also
