Why can't I find a new pair of CV Axles?
Fife, WA
1992 Mazda Navajo LX
Been searching for a week now. Ebay, AutoZone, Advanced Auto Parts, O'Reilly's, Amazon, RockAuto,and just google in general. WHY is it so hard to find replacement CV axles? I'm looking for front ones specifically.
Someone please correct me if I'm not on the right track.
This started because of a clicking in my front drivers side while turning right. It's gotten worse and it's driving me nuts on top of the fuel stalls I've been having. I'm preparing for the possibility of weekly 6 hour trips. This is just another hitch. Any help would be a godsend.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
What year is your truck?
Albino 94LTD
Recovering from Moab 2016
Newcastle Wa
White 94 Limited
Callsign
KG7PKQ
Your profile says you have a 93 sport. The only way the clicking could be the axle shafts is if you're driving around in 4wd (highly doubtful).
You may have other issues like wheel bearings or a bad automatic hub.
If it is an issue with the axle shafts an easier fix is to replace the U joints. It'a about the same amount of work as installing new shafts or rebuilt ones
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
1993 does not have CV axles it has axle half shafts with U joints
Fife, WA
This completely solves the question of why it's so bloody hard to find. It doesn't exist. Lol
I guess it's time to go find that ChrisFix video on replacing U joints...
Thanks guys! Especially Albino. I'm actually relieved to hear that it's probably the U joints. CV axle replacement looks like hell for someone like me with very few specialty tools.
Albino 94LTD
Newcastle Wa
White 94 Limited
Callsign
KG7PKQ
Stub shaft U joints aren't a piece of cake either. You have to take the spindles off to get them out and one of the 2 on the passenger side is locked into the diff with a 'C' clip. That's a major undertaking to get that inner stub shaft out and leads to a 'C' clip elimination modification.
But, it can be done in a driveway, not quite as easy on the trail but still doable.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
that inner U joint can be changed out in the truck............with a ball joint press
S Can’t find the hood cable on my ‘93 Explorer Stock 1991 - 1994 Explorers 0
T Where to find Parts Stock 1991 - 1994 Explorers 3
M The 1994 Navajo LX Barn Find Restoration Project Stock 1991 - 1994 Explorers 26
A 1993 Explorer Gas leak Cant Find it Stock 1991 - 1994 Explorers 5
oxic_berry Where to find a new wiring harness Stock 1991 - 1994 Explorers 1
T please where can I find that part ??? Stock 1991 - 1994 Explorers 11
H Barn Find 1993 Explorer Stock 1991 - 1994 Explorers 4
T What are the "hard to find" parts? Stock 1991 - 1994 Explorers 38
B 94 explorer cant find camshaft position sensor Stock 1991 - 1994 Explorers 2
T can't find the answer Stock 1991 - 1994 Explorers 7
L Electrical problem - Fuse 8 in Power Dist. Box blows - How do I find the fault? Stock 1991 - 1994 Explorers 2
J can not find delete post Stock 1991 - 1994 Explorers 1
B cant find egr or dpfe sensor Stock 1991 - 1994 Explorers 11
Roadrunner777 What did Roadrunner find in his diff? Stock 1991 - 1994 Explorers 8
M How to find out about gear ratio Stock 1991 - 1994 Explorers 2
D Quick Where to Find Replacement Question Stock 1991 - 1994 Explorers 5
S Where do I find what alternator I have? Stock 1991 - 1994 Explorers 3
R I have a hub problem that i cant figure out or find answer to! Stock 1991 - 1994 Explorers 9
L Can't seem to find blower resistor on 92 Explorer!!?? Stock 1991 - 1994 Explorers 7
T Where to find new leaf spring hangers? Stock 1991 - 1994 Explorers 10
J need to find transmission model # Stock 1991 - 1994 Explorers 4
K Coolant leak. I can't find it! Stock 1991 - 1994 Explorers 3
davy crockett Where to find front shock bushing? Stock 1991 - 1994 Explorers 5
MEANEXPLODER i searched but could not find the answer so im gonna ask Stock 1991 - 1994 Explorers 2
9 Help me find my Explorer I sold Stock 1991 - 1994 Explorers 8
H where to buy as can not find any used! Stock 1991 - 1994 Explorers 8
T Where Can I Find a New Upper Spring Bucket? Stock 1991 - 1994 Explorers 5
G can't find egr 91 sport Stock 1991 - 1994 Explorers 7
srknova74 Where can I find a new gas tank?? Stock 1991 - 1994 Explorers 12
T Custom parts..where to find Stock 1991 - 1994 Explorers 1
T I need to find the EGR pipe. Stock 1991 - 1994 Explorers 9
J where do you get hard to find parts for explorers Stock 1991 - 1994 Explorers 9
T How do i find what package my 92 explorer is? Stock 1991 - 1994 Explorers 5
K Where can I find a front spindle for my '92? Stock 1991 - 1994 Explorers 7
F Help can't find parts Stock 1991 - 1994 Explorers 9
P Missing vacuum line? Help me find it please! Stock 1991 - 1994 Explorers 15
Darrman Trying to find a check valve grommet! Stock 1991 - 1994 Explorers 6
O Help! AntiLock and Brake lights on-can't find problem Stock 1991 - 1994 Explorers 10
P 94 limited, where can I find new drivers leather seat upholstry? Stock 1991 - 1994 Explorers 5
Four0Sport where to find 2dr rockers Stock 1991 - 1994 Explorers 1
P 94 LMTD, Where can I find the Trailer/Towing electric Hookups? Stock 1991 - 1994 Explorers 14
J Probably an obvious question, but I can't find the answer anywhere Stock 1991 - 1994 Explorers 3
B How to find out what radio it had from factory? Stock 1991 - 1994 Explorers 16
N EGR VALVE not opening and closing? Can't find it Stock 1991 - 1994 Explorers 10
M Help me find the plastic arm for a Door Lock. Stock 1991 - 1994 Explorers 4
B Where to find factory Heat reflective Fabric Stock 1991 - 1994 Explorers 7
dingel5 '91-Trying to find a radiator fan Stock 1991 - 1994 Explorers 4
9 Where to find Freeze Plugs? + clutch brand ? Stock 1991 - 1994 Explorers 3
C a find at the junk yard Stock 1991 - 1994 Explorers 3
M 93 Eddie Bauer - Help me find a Power Seat Switch Stock 1991 - 1994 Explorers 2
Similar threads
