mikeh
- August 2, 2001
- St. Louis, MO
- 98 XLT SOHC V6
So I'm at 90K and getting ready to change my plugs out. Do you think it's really worth it to change out the plug wires while I'm at it? I don't know anyone that does this. Would this be part of a regular maintenance by Ford if I took it in for 100K tune up? Do you think I'm better off just checking them and leaving them on? I would check them by running the engine at night and wiggling the wires and seeing if I can see any spark from grounding.
Motorcraft wires at ORielly are $53. Is this just being cheap not replacing them? I'm on the fence as I've never had a problem caused by bad plug wires.
