Why Don't The Remote Mirrors Work? | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
readgoat70
Wake Forest NC
1992 Explorer XLT
The control switch in the driver door will move the driver side mirror left and up, but not down and right.
Similarly, the switch will move the passenger side mirror left and up, but not down and right.
Is this a coincidence?
Is this a switch issue or a mirror issue?
Thanks for any help diagnosing the problem . . . . .
Harry
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
readgoat70
Wake Forest NC
1992 Explorer XLT
Thanks, Donner, for the timely reply . . . .
I didn't bother replacing the fuse yet . . . . . the switch does move the mirrors in two directions. I figured if the fuse blew, the mirrors wouldn't move at all.
DeRocha
NEX Vice President
Moderator Emeritus
Brockton, MA
'93 XLT 4x4
Some times dirt or sand can wedge itself under the switch preventing it from making contact.. Try using compressed air to blow it out, or a vacuum cleaner to draw it out. When cleaning make sure you are moving the switch in all positions as the dirt could be trapped under the contact and only freed when you move the switch to another position.
readgoat70
Wake Forest NC
1992 Explorer XLT
And yes, there is a slight grinding noise when the mirrors move up and left.
Donner
Natomas/Irvine
01 Sp 03 XLT 4x4s, Scion
That part is good...
There should be that sound, so that's good. Both sides not moving in same direction might be an issue with the switch itself as you suspect... Have you gone through the Forums under electrical issues yet? If not, peek through there, I'm going to look also...
I just kinda went through there, and it appears you might need to look at the wiring - I don't know if this is something you'd try, but the postings recommend opening the door panel and looking at the wiring. Lose, unattached, broken... also replace the fuse and see what happens.
readgoat70
Wake Forest NC
1992 Explorer XLT
Thanks, Donner, I couldn't find a forum that was specific to electrical issues . . . Did I miss it?
what is the link . . . . . . ?
walterd140
Ludlow, Massachusetts
'94 Sport
Had the same issue & I replaced the switch in the armrest. All problems went away. Ripping the old switch apart (morbid curiousity to see how the darn thing worked) & I found some contacts so corroded that I wondered when they EVER worked.
Then came the day the dog went through the side window deflector & I had to rip them off. Watched during the next rainstorm as the water from the open crack in the window dripped right onto the mirror & door pad. Go figure, that is where the corrosion starts at.
Taking the pad off is easy, just a straight head screwdriver in the lower & upper ends will (GENTLY) pry it up, then the mirror, window, door electrical pad is in hand. 2 Phillip screws after that & all is apart. Reverse order to put it back together, unless you have a cold one. Then every action requires another brew :)
Walter
lmatt
1991 explorer 4dr EB
My 91 did the same thing. All it took to fix was the switch. Ford # is
F3ly 17b676 a.
1IronMike
Sacramento, California
1994 XLT
Chances are its the switch. My old 93 was broken when I got it. Turns out that there is no fuse or too big of one and there is a recall to install a jumper and fuse. Check with you dealer. He will run the vin number and check for recalls and see which one were not done. There is also a recall on the rear hatch support rods where the attaching pawl attaches to the hatch.
ShadowdogKGB
Tioga County, PA
'91 Navajo
For the record mine does the same thing. Must be pretty common. It's a helluva annoyance.
BIGHVM
UK, Richmond, Surrrey.
2000 Northface
This is probably a problem in the mirrors, its not uncommon, what is inside them is this- Imagine at 12 o clock a powered screw adjuster and again at 3 o clock another, when you press the switch to move the mirror up, the screw adjuster gets wound in or out thats all that happens, they are fixed to the mirror backing plate by a push fitting, apply even pressure on your mirror using something flat- NOT YOUR HANDS in case the glass breaks, keep the pressure even or you may crack the glass- it should pop back onto the fitting. How do I know this...........my car was vandalised, the idiot kicked my mirror and it fell apart! I had to do just that to fix it- IT worked for me!!
PLEASE BE CAREFUL, TAKE CARE AND THE TIME TO DO IT- DO NOT PUCH TOO HARD!!!!
