clarks2001
- April 22, 2008
- Ashburn, Virginia
- 2002 Explorer Limited
Well it stalled once but sometimes the idle dips down to right before it stalls. Usually happens when I am stopped in gear or going from reverse to drive gear. Today it died while i was at the ATM and it was in drive.
My battery is only months old and dealership said my alternator is fine. The belt is new also. I ran it to 5000 rpm during accelerating to see if it would help and it still idles the same way. Note that I dont drive it like that all the time, this is actually the first time I got the RPM up that high, I usually run up to max 3,500 rpm before the gear changes.
I may clean my MAF sensor and replace air filter to see if that helps. What should I use to clean the MAF? I was thinking that dust off stuff but open to suggestions.
I got just over 96000 miles on it (4.0L)so the plugs are soon to get swapped and coolant flushed, and differential fluids changed out and transmission fluid changed also. But thats a few months down the road yet. Any ideas would be appreciated.
