Will a '98 5.0 manifold fit a '96 5.0? | Ford Explorer Forums - Serious Explorations
Explorer96xlt
Maitland, florida
'96 XLT 5.0
I have a 1996 ford explorer 5.0L, my right hand side manifold is cracked, and im getting tired of the ticking. someone has a manifold for sale from a '98 5.0 limited.
will the 98 manifold fit my 96?
Yes, but the passenger side one will have an port for the EGR tube. So it would have to be plugged up.
Section, I am asking because I don't know, but the 96 5.0L manifolds are for the non P heads.
The 98 will have P heads, so I assume you are saying the manifoldsfit both heads?
It makes sense I just want to be sure, I know the TM headers will fit both heads.
The angle of the spark plug is the only difference?
can i ask what the egr port and the egr tube does?..i really have no idea.
http://www.fordfuelinjection.com/
Everything you ever wanted to know about EGR.
IN 96-mid 97 the 5.0L EGR was external (metal tube from top of pass side manifold to intake)
IN 97.5+ the 5.0L used the "P" heads, and the EGR is plumbed internally, through the heads and into the intake (no tube)
I think you got those backwards? :p
Yup I do sorry, hahah my BII has an EGR tube, with a 97 engine with P heads.
My 96 Explorer's withouth the P heads have no EGR tube.
Hey all 3 trucks look similar under the hood! cut me some slack :p hahaha I have been under all three hoods lately too!!
are the 97+ manifolds shaped differantly then the 96's ?
ive looked under the hood..and i cant find an EGR tube
You dont have one as stated above I had it backwards, the P heads = EGR tube.
The elbow to the throttle body is the difference between the upper intakes, only, as far as I know.
