Will Aftermarket Fenders get me 33's?? | Ford Explorer Forums - Serious Explorations
One thing ive been saying is i wish i could lift the "front" of my X another inch or two to fit 33's. Just had a brainstorm...
Would aftermarket fenders allow for 33x12.5" tires?
The height isnt really the problem, its the turning width. So i wasnt sure if this would matter in tire fitting.
If it would work. what fenders should i go for on my 98 Sport? (websites are appreciated on this one)
What's your setup now, including wheels?
Don't forget the sawzall in this instance....Much cheaper to trim than add fenders.
2" PA BL
2" (really 1.5-1.75") TT
4door leaf springs
double AAL
War153 shackles
32x11.5x15 Tires on 15x8 rims w/3.75" backspacing.
Had slight rubbing and trimmed fenders a little. Ever since i have never rubbed- even offroading i dont rub.
Yes, you should be able to clear 33x12.50s easily with fenders in the front, you probably won't need them in the rear, just a teeny bit of trimming.
Fiberglass fenders
You would easily fit 33 with these fenders. I bought mine from Hannemann's. Much better quality and an awesome guy to work with.
The 15x8s will be fine.
So my list is
2 Fenders
4 33" Tires
Paint
Gonna be an expensive endevour!
Im good with my stock 4.10 gears here or no?
*this is tough because i was planning on putting in a new engine (same 4.0 SOHC but w/mods and a 5spd tranny) within a few years..
The 4.10s will be fine.
How hard is the trimming required to fit these? I figure i can afford that now. And i commute 60 miles everday to school so hopefully someone will change lanes without looking and wallaaaa... matt gets new fenders a la insurance de retarted driver :D
Originally posted by Hokie
wishing you had done a 3" bl?
Naa.. love the 2" BL.. looks good. If i did 3" id want to fit 35's !!!
I think after the fenders and 33;s ill have the perfect combo for commuting/offroading
yea, but width is just as important as height. I like the looks along with the grip of wide tires. 33x10.5 would look wierd. 32x11.5 look cool and perform good. 33x12.5 look and perform awesome. and any larger than that would kill my commute!
FYI: My tires will be AT's not MT's even if i upgrade to 33's
Well, just an FYI, doing the Perry's Fenders is how I got on 33"s... So I'm guessing it would probably work for you too...
Between work and school I probably commute anywhere between 40-60 miles a day with 35" M\Ts, it's not as bad as you might think. I have a 5 spd manual, and 4.10s and i average around 16 mpg. I'm runinng 35x12.5s on 8" rims with basically one more inch of lift than you so you shouldn't have much of a problem with rubbing.
