Will ford release Sync V 3.4 on the Explorer | Ford Explorer - Ford Ranger Forums - Serious Explorations
grizzyxd
d
2017 Explorer XLT
I’ve tried looking up to see if I can update my explorer but i haven’t had any luck.. I’ve seen a couple ways to update unofficially using ”cyan labs” but I’m scared that it would break my APIM Or void my warranty will ford release an official version of sync 3.4 for the explorer
MM07
MA
2018 Explorer Limited
I doubt that will happen.
That is why so many people, including myself, have upgraded to 3.4.
I have had no issues. Also have taken it into service and no one said a thing.
grizzyxd
d
2017 Explorer XLT
So like it won’t void my warranty because Peter stated on the other thread that it will
MM07
MA
I don’t know that answer. I did it anyway.
G8orFord
LAUREL HILL
2016 Explorer Sport
The files used are actually Ford files. The 17+ APIM is fully capable of running 3.4, but they changed the allocated memory sizes to accommodate the newer version, so the internal storage has to be reformatted to accept the new files. Ford doesn't want to have a bunch of failed updates to deal with if the reformat glitches. They will not be updating our units to 3.4. Cyanlabs figured out a way to do it reasonably safely. I've done two. My '16 Explorer (bought a 3.0 APIM and installed it) and my '17 F-250. Both worked fine.
As far as warranty, I probably wouldn't try to do a warranty claim on the APIM, but I see no reason it would void the warranty on any other system. Magnuson-Moss should be all you need to say if they were to try an deny a claim. The only thing affected by the update is the APIM and with the exception of the reformat, it's all FoMoCo files.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
The 2020 Explorer and Aviator are running on version 3.4 of Sync 3. The latest release updated it to build 20136.
grizzyxd
d
2017 Explorer XLT
I
I currently have a 2017 Explorer will it still work
peterk9
Staff member
Moderator
Callsign
VE3
jmr061
Wisconsin
16 Exp Sport
If you are under warranty and you have an APIM related issue like an APIM failure or a slow down in APIM response, your APIM will not be covered under warranty as you put unauthorized software in it.
VoltaicShock
2017 Explorer Limited
I would take a look at this tool:
Here is the tutorial:
suzook
ny
2018 Explorer XLT
Very doubtful. I dont know why they wouldnt, as it runs very well.
grizzyxd
d
2017 Explorer XLT
Thank you I have done the upgrade and it works phenomenally took 9 minutes to update because I don’t have nav
grizzyxd
d
2017 Explorer XLT
i have done the upgrade unfortunately I didn’t like it Was really laggy is there anyway to go back to sync 3.0 that furthest I was able to go back was 3.3 but it was still laggy I want to go back to sync 3.0 build 19205 is that possible
G8orFord
LAUREL HILL
2016 Explorer Sport
Did you do a factory reset after the install? I've installed it on two vehicles and it's less laggy than v3.0 on both. Granted, they're both 2017 APIMs.
MM07
MA
I would try that or the APIM restart.
3.4 is great on my 18.
jmr061
Wisconsin
16 Exp Sport
No, you can not go back 3.0
suzook
ny
2018 Explorer XLT
Laggy? That makes no sense. All of us have noticed its ATLEAST as good, or better than 3.0. Theres something wrong if yours is laggy.
Zodiac
2017 Ford Explorer Sport
Have you noticed any major changes other than the UI?
I was tempted to do the upgrade and then upgrade the 2x USB ports in the center console to one that has a USB-C port so I can fast charge my phone while using AA.
MM07
MA
@Zodiac, I’d say go for it.
Yes the UI has changed. Overall it is just better in my opinion. As I have said before, I’m glad I did it.
VoltaicShock
Did you do a master reset?
Step 5:
Once fully booted go to Settings > General > Master Reset, this will clear a lot of bugs and other incorrect information and will be the first thing i tell you to do if you have any issue.
