Will these work | Ford Explorer Forums - Serious Explorations
Will these work
tonga3
Brooklin Ontario
99 exp. EB 5.0
Will the ford 1.72 roller rockers for the mustang work on the explorer? I am assuming that they mount the same and I shoulden't have any problems if I but a used set off a mustang guy.
Thanks
Andy
as long as they are pedastal mount, and not stud mount, then yes... they will work on your explorer.
i would recommend NOT using them though. all the 1.7's do really is move your powerband up in the rpm range. this is not what you want in a 4500lb automatic suv. for the 4 peak hp you will gain higher up top you will loose over 10ft.lbs. lower down.
Were the mustangs different mounts for different years? How would I know if they were stud mount or pedestal mount?
if they are stock Cobra's, then they are pedestals (bolt on).
