tompkinswest
- July 9, 2008
- Oregon
- 2003 xlt flex fuel
Hi...I have an 03 explorer with a bad window motor on the front passenger side door. Can anybody give me some advice on how to remove and replace it? The window is stuck in the down position and I tried to remove the entire regulator assembly but it wont fit out of the top of the window slot. I dont know how to remove just the motor as it has a gear assembly attached to it with 2 cables coming out of it. I'm positive that the motor is bad as I had the switch tested . I can also only hear the motor engage (click) when I hit the down side of the switch. Thanks!!
