Badgerfan79
- September 22, 2015
- West Michigan
- 2020 ST; 2021 Limited AWD
I have a 2020 ST and the driver window wouldn't roll up the other day. Took things apart and the wire was all discombobulated and so essentially the regulator system is shot. It's completely different than any other window regulator I've replaced. I found a decent vid for getting it out but they don't follow through with replacement. Does anybody have a link to the procedure or has anyone done it that could give me some tips or advice? Thanks in advance.
Edit: I did find a video that shows the install as well but if you'd like to share, I'd still appreciate it. Or just vent! That's okay, too! At least I'm going to make it worthwhile by upgrading the 3" and 6x9" door speakers and add some deadening material. Shrug.
