window stuck down
stew17
Bel Air, MD
'93 Eddie Bauer
Alright this is my first post. My 1993 Explorer 4-door front passenger window has been working fine, one day it made a grinding noise going down and would not go back up. These are power windows, there is no noise coming from the window motor when the switch is pushed, and all the other windows work fine. Since there is no noise coming from the motor, does that mean the motor is the problem? Also My Chilton manual doesn't show any instruction on the window motor itself. Any info would be great thanks
something9000
naples fl
1994 navajo
if it made a grinding noise before it stopped yeah its probably the motor but it could be the window somehow got off track and the motor wedged the glass and got it stuck when you last lowered the window. The first thing i would do is take the door panel apart and see what things look like inside there. Also The haynes manual doesnt really have motor instructions just for the regulator.
ranger-93
Fayetteville, GA
93 ranger, 01 f-350
take the door panel off and get a rod or pipe just something with a lil weight behind it. give the motor a good tap WHILE holding the button to raise the window. if this works you need to replace the motor. i did this for a month or two cuz the motor was random on working and finally got tired of whacking the door panel with my hand or if that didnt work id take panel off and tap motor and finally just replaced the motor.....now my drivers side is going out lol
Mudboy
Bellmawr NJ
91 ex
As everyone else has stated, pull panel off. see if you can get the window to go up by hand at all. Inspect everything look for the obvious. get a test light and look to see if you are getting power to the motor when the switch is pressed.
stew17
Bel Air, MD
'93 Eddie Bauer
Ok thanks, now to take out the window motor does the window glass and regulator have to come out as well?
johnsonhalo
hell hole arizona
92 Explorer Sport 4X4
i'm new here too, and you might want to make sure it is actually the motor before you spring to replace them. i replaced both my passenger and driver motors because both windows had gotten stuck down. this worked for maybe a month and now both windows are stuck down again. replacing the motors is not too terrible so long as you leave the regulator in though. from what i've read this is pretty common and i guess usually it has to do with wiring?
stew17
Bel Air, MD
'93 Eddie Bauer
Thanks to everybody who replied to this post, I ended up needing a new window motor.
M Window issues, passenger side stuck down. Stock 1991 - 1994 Explorers 10
B pass PWR WINDOW stuck down.how screwed am i? Stock 1991 - 1994 Explorers 7
T Driver window stuck down! Stock 1991 - 1994 Explorers 18
J Rear doors window frame Stock 1991 - 1994 Explorers 0
kmack Free - 3M Window Weld ribbon sealer Stock 1991 - 1994 Explorers 5
W Which is the driver/passenger window motor?? Stock 1991 - 1994 Explorers 0
G Power window issue Stock 1991 - 1994 Explorers 5
S Courtesy Lights - Rear lift gate/window Stock 1991 - 1994 Explorers 22
S rear cargo lift window seal Stock 1991 - 1994 Explorers 3
S ohv cam window Stock 1991 - 1994 Explorers 9
KlimFord Power Window Puzzler Stock 1991 - 1994 Explorers 21
S 1993 Ford Explorer Window issue Stock 1991 - 1994 Explorers 6
7 Front Power Window Motor Stock 1991 - 1994 Explorers 8
P 1993 Explorer Power window problem Stock 1991 - 1994 Explorers 3
P Crooked window Stock 1991 - 1994 Explorers 10
D Window Issues.... Stock 1991 - 1994 Explorers 5
Number4 Window roller guides Stock 1991 - 1994 Explorers 2
S Window motor clicks, doesn't roll up Stock 1991 - 1994 Explorers 8
I Window motor bushings replacement- CHEAP SOLUTION!- also: motor runs, bushings intact, not working? Stock 1991 - 1994 Explorers 8
T Door lock and window switch illumination? Stock 1991 - 1994 Explorers 3
kmack How to remove door window trim? Stock 1991 - 1994 Explorers 1
F window seal removal Stock 1991 - 1994 Explorers 4
P Window moves two inches, rotates a few degrees, and jams Stock 1991 - 1994 Explorers 3
I rebuild/recondition window motors? Stock 1991 - 1994 Explorers 1
R Window motor question Stock 1991 - 1994 Explorers 3
mfitz725 Help w/ Drivers Window Stock 1991 - 1994 Explorers 7
mfitz725 Power Window Off Track? Stock 1991 - 1994 Explorers 5
M Front Driver's side window issue Stock 1991 - 1994 Explorers 2
G Ford explorer 1992 window problem Stock 1991 - 1994 Explorers 15
M Solved Window Gear Bushings Replacement trouble Stock 1991 - 1994 Explorers 4
F 2004 Explorer XLT quarter window replacement Stock 1991 - 1994 Explorers 1
M 1994 explorer rear passenger cargo window shattered Stock 1991 - 1994 Explorers 5
M 1994 4Dr explorer ( window issue ) Stock 1991 - 1994 Explorers 4
T Rear Window Broken Stock 1991 - 1994 Explorers 2
C driver side aster window control panel Stock 1991 - 1994 Explorers 1
V Rear window won't go down Stock 1991 - 1994 Explorers 2
J 94 explorer rear power window problems. Stock 1991 - 1994 Explorers 9
V Window motors front rear the same? Stock 1991 - 1994 Explorers 3
C '94 XLT - Trouble with Power Window Motor Stock 1991 - 1994 Explorers 7
D @$#&% window smashing thieves Stock 1991 - 1994 Explorers 12
M Solved Window won't work: NOT the "replace bushings" problem. Stock 1991 - 1994 Explorers 4
A power window slipping Stock 1991 - 1994 Explorers 5
T 92 Explorer Liftgate Window Fit Stock 1991 - 1994 Explorers 4
S MANUAL window problem Stock 1991 - 1994 Explorers 0
P Drivers window glass squeaks going down - Rain-X? Stock 1991 - 1994 Explorers 4
G Window UN-tint Stock 1991 - 1994 Explorers 15
M Window issues. Stock 1991 - 1994 Explorers 1
S Window problem Stock 1991 - 1994 Explorers 8
spinnn anyone know window motors Stock 1991 - 1994 Explorers 4
C power window problems Stock 1991 - 1994 Explorers 8
Similar threads
