tradar
- July 12, 2007
- Muskegon, michigan
- 1999, mountaineer
Ok first my rear washer worked and my front stopped, now both stopped. I checked the voltage at the washer motor conector and I get Like 2 volts when I energize the front, and 12 when I energize on the back. reading the same wires at the pump.
Now I did not pay attention to polarity.How does this system work?
Does this have a RELAY?
If so where is this at? I can hear one clicking but can not find it.
Also I did pull the washer motor and bench tested it with a battery direct.
It worked fine?
Thanks
It worked fine?
Thanks
