BoostedE21
- October 9, 2011
'91 4Dr XLT. My Driver and Driver Rear Window are experiencing some issues.
Driver window will go up and down, but about halfway up, i can hear the motor spinning but the window doesn't move unless I grab it and pull it up a few inches. Then the motor catches again. I haven't taken the panel off - is it possible that the motor is missing teeth? Or would this be an actual regulator issue?
Driver Rear doesn't move at all. I can hear the motor "trying," but it's not successful in moving the window. I think this might just be a worn out motor.
It looks like the cost to replace the whole regulator assembly + motor is about the same as just the motor....how difficult is the regulator assembly to remove? I saw an A1 Auto video where they were drilling out rivets....that's outside of my skill set, but if it's just a couple bolts, I'm good. What do y'all think?
