RickToro
- March 19, 2005
- Woodridge, IL
- 98 xlt
Not getting any voltage to the pump. Pump is good when connected directly to 12v. My first thought was the multi-function (MFS)steering column switch. However, there is no water to the rear window either. If the MFS was bad wouldn't the rear window washer at least work? I know the same pump washes both the windshield and rear window but isn't there a separate switch for the rear window or does both the front and rear washers go through the MFS? There is a separate button on the dash for the rear washer just not sure whether it goes through the MFS. Do you guys have any experience with this? Also, if it is the MFS, where is the best place to order it from? Thanks
