- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2023 Aviator Reserve 201A
- Callsign
- VE3
geezerglide , assuming that you are replacing 255/50R20 wheels/tires with the 255/45R20 ones, according to 1010tires.com, your diameter variance will be -3.34%. The generally accepted maximum variance is 3%. This would mean that if your speedo showed you were traveling at 100 kph with the 255/50R20 setup, you would actually be going 96.66 kph with the 255/45R20 ones.
