Winter Tires
bigdude2468
2014 Explorer XT
I have a 2014 XLT, 18" wheels, the standard tire size is 245/60-18. We spend five months in the winter in Utah where we drive the most avalanche prone road in North America, last winter we had 650" of snow. I want to buy a set of snow tires and wheels. The question I have is in 3, 4, 5, years when I trade in the 2014 and buy a 2022 or 23 will the snow tires fit the new explorer? The 2020 Ex still have 18" and 20" wheels but the tire size is slightly different. I looked at a 2020 Ex and the tires were 255/65-18. What happens if I were to put the 245/60's on the new Ex?
Mlarv5
Crossville TN
2017 Platinum Ruby Red
There really is no way of telling if your current tires and wheels will fit in the 2022 Explorer. Ford changed the design for 2020 along with the spec's, they seem to change options every 2 or three years to accommodate the changing market.
If it were me I would buy what I needed now and not worry so much about 3 or 4 or 5 years from now. By then you might not want an Explorer or you might want new and shiny.
KayGee
Farmington, MI
'16 & '17 PIU
If you are just talking tires, I don't see why you couldn't use the snow tires you buy now on another vehicle later. If you are concerned about size, you could always upsize slightly now so there is less of a size difference later. (Say 255/60r18 or 245/65r18)
If you are talking wheels also, I believe I have seen reports of them being same bolt pattern, but not sure on widths/offsets.
Best of luck.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
........................ The 2020 Ex still have 18" and 20" wheels but the tire size is slightly different. I looked at a 2020 Ex and the tires were 255/65-18. What happens if I were to put the 245/60's on the new Ex?
You'd be in the same boat as I would be. You would require new Winter tires if you want to stay within the recommended 3% maximum diameter variance.
255/65-R18 vs 245/60-R18 Tire Comparison - Tire Size Calculator | Tacoma World, or Tire size calculator: compare tires online
A 235/70R18 is very close to the same size as the 255/65R18 with a difference of only -0.03 255/65-R18 vs 235/70-R18 Tire Comparison - Tire Size Calculator | Tacoma World, or Tire size calculator: compare tires online
I use the 18" steel Interceptor wheels in place of my 20" OEM wheels but the new Explorer has also changed the 20" size so I will have to get new Winter tires, assuming the 18" wheel will fit.
03WIExplorerLtd
2011 Explorer FWD base
Remember, winter slicks don't last as long.
Always can get different wheels provided lug nuts work. I will be looking at new set this winter in WI. Had set of Bridgestone DM-1 had 2014/15 winter to 18/19. They were decent, essentially all season this past winter. New models since then, check tire rack
KayGee
Farmington, MI
'16 & '17 PIU
What do you mean by this?
Every set of winter tires I have that was used during the winter months (roughly nov-mar for me) has lasted many years. I have had several sets that only saw about 1/32" of wear per year and probably would have lasted 8-9 years at that rate if I wanted to push them (as they started with 10-11/32" of tread). I usually replace my tires when they get to 3-4/32" or after 6 years of use. Most vehicles I run snow tires on are daily drivers, so they see 10-15k miles per year with 5-7k of that in winter. 35-45k miles or more out of quality snow tires is perfectly reasonable and many have gotten much more. Also, most manufactures of winter tires say to expect at least 4-5 seasons of use from them.
Winters can wear prematurely if you drive them outside of the range of temperature/conditions they were designed for (ex. in the summer/above 42 degrees consistently), but that would be an owners fault.
03WIExplorerLtd
They are softer rubber and do not last as long as all season tires. By design
At 6/32 they do not have any winter tread left, its all season. I would expect y all seasons to last longer
peterk9
Staff member
Moderator
Callsign
VE3
They may not last as so-called all seasons but they allow you to extend the time that you get to use them since you don't use them all year. Even with the tread worn down. the softer compound will still grip the cold bare roads better than the OEMs. That is why they are now referred to as Winter and not snow tires.;)
KayGee
Farmington, MI
'16 & '17 PIU
Everything varies by tire brand /model and how they are used. I know people that leave their snow tires on all year and wonder why they are shot in less than 2 years of driving or why they had a blow out in the heat of summer. When used properly, they have more than adequate tread life.
Tire rack recommends replacing Winters at 5/32", but if you started with 12/32", that's a lot of tread life. The key with winter tires is not to drive on them at temps above ~42° as that will cause them to wear more quickly.
I believe transport Canada says 5/32" is min for snows. Some tire shops say down to 4/32" is fine and others say to replace when they get to 7/32" (which seems a bit ridiculous).
All depends on how much snow/slush/ice a person encounters in their area. I have driven on winter tires in mi down to 3/32" and they were still light years better than even new all seasons.
Kal tire did a study comparing snow tires to all seasons at 25/50/75/100% wear and 100% worn snow tires still allowed same or better snow cornering and ice braking than brand new all seasons.
Mine were junk at 5 to 6/32.
I've bought many snow tires (premium to much lesser known brands) over the years and never had any that were junk at that wear level. Some people just seem to have more problems than others...
onestout
2015, Explorer XLT 3.5
Snow tires will have 2 sets of wear marks in them, 1 for when the snow effectivity is gone and 1 when they are no longer legal to use on the road. The more premium winter tires are all-season tires capped with a winter compound, once that compound is gone you may as well use them in the summer until they are wore out. I don't put a lot of miles on per year and a set of snow usually last me until I sell the vehicle.
peterk9
Staff member
Moderator
Callsign
VE3
............................................. The more premium winter tires are all-season tires capped with a winter compound, ................................................
Do you have a link to that info? BTW, the term "snow" tire is an outdated term since it doesn't accurately reflect the true capabilities of the tire, mainly improved cold weather traction.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Winter tires will last a long time in the conditions they were made for, cold of course, but the road surface matters more than that. Winter tires will wear out the fastest on bare pavement, at any temperature. So be easy driving on pavement with Winter tires, avoid hard cornering. On snow you will naturally drive easier than on pavement, which helps them last a lot longer.
My old Winter tires are over ten years old I'm sure, I just bought a new set to replace them. So the old ones though not dry rotted, I need to put on this Winter, and leave them on until I wear them out.
onestout
most tire manufacturers say or not if they are a dual compound on their website in the information. Blizzak's were one of the first many years ago to do this, I think they were from the start, my X-ice are this way also. My General Arctic's were not, that softer compound makes for a lot of flex in the sidewall.
peterk9
Staff member
Moderator
Callsign
VE3
....... that softer compound makes for a lot of flex in the sidewall.
That's what I was concerned about. If it was an all-season tire capped with just a softer compound added to the tread, the sidewall would still be stiffer. I wasn't able to find anything about the '2 stage' manufacturing.
Steve Boat
IL
2016 Explorer Limited
I did Blizzak tire on mine first snow they seemed GREAT! I will post again when they have 5K on them
Ironworker40
new jersey
2015 Explorer XLT
I found this on tire rack
NOTE: The first 55% of the Blizzak DM-V2's tread depth features the NanoPro Tech Multicell Compound while the remaining 45% features a standard winter tire compound. When the Blizzak DM-V2 is approximately 50 percent worn, a depth indicator molded into the tread design lets the driver know that the remaining tread is reaching the end of its ability to provide beneficial snow traction
Good to know as I own a set and I din't know this.
peterk9
Staff member
Moderator
Callsign
VE3
I have the same tires just installed and noted that message on the Tire Rack site when I was doing some research on various tires.
S What tire/wheel size are you running for winter tires? Stock 2011 - 2019 Ford Explorer Discussion 7
E My winter tires are on Stock 2011 - 2019 Ford Explorer Discussion 5
R New Winter Tires Diameter Change Stock 2011 - 2019 Ford Explorer Discussion 38
T 2012 xlt and snow Chains vs winter tires Stock 2011 - 2019 Ford Explorer Discussion 20
P Winter tire size options for 2015 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 4
X Winter tire shopping in Canada suck.... Stock 2011 - 2019 Ford Explorer Discussion 35
F So Done with this Winter!! Stock 2011 - 2019 Ford Explorer Discussion 18
C Show off your winter explorations Stock 2011 - 2019 Ford Explorer Discussion 21
B How's the Sport in winter weather? Stock 2011 - 2019 Ford Explorer Discussion 17
A Fwd Ecoboost winter driving question. Stock 2011 - 2019 Ford Explorer Discussion 3
R Winter complaints Stock 2011 - 2019 Ford Explorer Discussion 48
T Winter package promo Stock 2011 - 2019 Ford Explorer Discussion 15
B Fwd explorer in winter Stock 2011 - 2019 Ford Explorer Discussion 26
1 Winter Tire and Wheel Recommendations Stock 2011 - 2019 Ford Explorer Discussion 651
M 17s with bigger tires on 2016 Sport?? Stock 2011 - 2019 Ford Explorer Discussion 2
K New wheels and Tires in 2016-19 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 1
W New wheels/tires on '17 Sport Stock 2011 - 2019 Ford Explorer Discussion 6
M Sport wheels and tires with Ford tire sensors Stock 2011 - 2019 Ford Explorer Discussion 7
C Explorer Eating tires, alignment off in 6 days!! Stock 2011 - 2019 Ford Explorer Discussion 0
S 2014 explorer base model upgrade tires Stock 2011 - 2019 Ford Explorer Discussion 16
L All 4 tires brown on inside track, just bought Stock 2011 - 2019 Ford Explorer Discussion 6
X Noisy Tires 26k miles Stock 2011 - 2019 Ford Explorer Discussion 25
B Looking for to find info on tires for my 2014 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 3
S What All Season Tires are you Using? Stock 2011 - 2019 Ford Explorer Discussion 15
S Bigger tires more or less air? Stock 2011 - 2019 Ford Explorer Discussion 6
B Lifted 2014 explore sport eating tires Stock 2011 - 2019 Ford Explorer Discussion 20
F Which OEM tires come on Explorers? Stock 2011 - 2019 Ford Explorer Discussion 28
P Tires! Stock 2011 - 2019 Ford Explorer Discussion 1
W Front end noise...Tires? Bearings? ?? Stock 2011 - 2019 Ford Explorer Discussion 20
B Review: Continental ExtremeContact DWS 06 tires Stock 2011 - 2019 Ford Explorer Discussion 9
1 Need new tires, just bought Interceptor wheel set Stock 2011 - 2019 Ford Explorer Discussion 1
P OEM Tires Lack of Road Hazard Stock 2011 - 2019 Ford Explorer Discussion 14
M 2016 Sport tires Stock 2011 - 2019 Ford Explorer Discussion 23
S Need some advice with rim and tires Stock 2011 - 2019 Ford Explorer Discussion 1
T Recommend a good set of off road/beach tires Stock 2011 - 2019 Ford Explorer Discussion 25
P New tires... PIU specific question Stock 2011 - 2019 Ford Explorer Discussion 7
K Please recommend all weather tires! Stock 2011 - 2019 Ford Explorer Discussion 33
C 2013 Explorer Sport - just got new tires Stock 2011 - 2019 Ford Explorer Discussion 4
H All Terrain / Off Road Tires Stock 2011 - 2019 Ford Explorer Discussion 62
S Tires and daylight running lights Stock 2011 - 2019 Ford Explorer Discussion 4
H Any interest in purchasing single OEM Sport tires for full size spare? Stock 2011 - 2019 Ford Explorer Discussion 4
N Wider tires Stock 2011 - 2019 Ford Explorer Discussion 12
T Mods, might it be worthwhile to start a dedicated "Explorer Tires" thread or sticky? Stock 2011 - 2019 Ford Explorer Discussion 6
T Nitto Crosstek Tires for 2013 EX LTD 4WD Stock 2011 - 2019 Ford Explorer Discussion 6
O How would you rate tires on XLT Stock 2011 - 2019 Ford Explorer Discussion 5
G Time for tires Stock 2011 - 2019 Ford Explorer Discussion 678
H Michelin Tires Stock 2011 - 2019 Ford Explorer Discussion 32
T Summer tires vs. all seasons? Stock 2011 - 2019 Ford Explorer Discussion 5
S Do I have dry rot on my '11 tires already? Stock 2011 - 2019 Ford Explorer Discussion 31
G Tires - 2013 Sport Stock 2011 - 2019 Ford Explorer Discussion 17
Similar threads
