wireless internet
College Student
Indinapolis, IN
'03 EB
i know probably not the best title but it fits
My question: Is there a way to remote signal boost a wireless signal?
I am asking because my computer is upstairs wireless down and the signal is weak and really slow?annoying when im up there, something that can take 10 minutes to download will take over an hour, so im in no hurry but i would like there to please be a solution
Howard
Moderator Elite Explorer
Staff member
Moderator
Milton Keynes
1998 SOHC UK SPEC
Depending on what router you are using there are several Wireless extenders (repeaters) available. Best to get the one that goes with your router manufacturer. Or you could go for a mains network solution where you use the house wiring for your network.
00tec-satx
Dacono, CO
2002 XLT
Depending on the model of the router you may be able to install custom firmware like dddwrt and boost output
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
Install business class wireless devices.. I use Engenius products on installs in warehouses.. most home routers put out like 20mW of power to the antenna.. The ones I deal with put out close to 400-600mW
College Student
Indinapolis, IN
'03 EB
thanks for the ideas, and comercial sounds awsome but i was hoping for a relatively cheap solution
Joe Dirt
07 Camry
That thing is badass!
College Student
Indinapolis, IN
'03 EB
so jad is that like just putting another antenna on the existing router or is it somewhere else in the home and howard does that somehow plug into the wall then transmit signal, I'm still confused i need abook for dummies and i don't know the euro translation either
Howard
Staff member
Moderator
Milton Keynes
1998 SOHC UK SPEC
They come as a pair. You plug one in near the router and connect the network cable from it to the router. You plug the other near the computer and plug the network cable from it to the computer. The network signal is transmitted via the mains wiring from one unit to the other. I've used them here with great success. They don't even need and setting up just plug in and away you go. Obviously you will need the US plug versions.
Such as these http://www.newegg.com/Store/SubCategory.aspx?SubCategory=294&name=Powerline-Networking
College Student
Indinapolis, IN
'03 EB
looks like i ned o save up a lil bit, do these still work if it is an old house with two prong wirews.......
Howard
Staff member
Moderator
Milton Keynes
1998 SOHC UK SPEC
I have no idea as we all have the three pin type connectors, but I see no reason why they shouldn't. If they come with that type connector.
jad2411
El Paso, TX
2007 Brown eb
the antenna I linked can be connected to either the card, or the router, it comes with a few adapters.
If your card or router don't have removable antennas, then this won't work for you
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
2001 Sport (sold)
