gt183
- May 8, 2008
- Long Island, NY
- '05 XLT
So I've been working on a little project for the last couple of months, and I'm up to one of the last steps of wiring the relay. My first attempt at this I messed up crimping the disconnect terminals with the supplied relay:
So I decided to go with a solenoid style relay so I can just use some O-Rings instead of the clips:
Can someone explain how I should wire this up? The wires I have to connect do the following:
1: Power from the battery (10 Gauge)
2: Power to the device (10 Gauge)
3: Switch (16 Gauge)
4: Ground (16 Gauge)
From the research I've tried to do, it seems that the two larger connectors are for power, and the two smaller ones are for grounding and switching. It doesn't seem to matter which of the two larger poles you use to hook up your power to, but would this be the same for the ground and switch?
Thanks in advance!
Thanks in advance!
