edash
- March 6, 2011
- Chapel Hill, NC
- 1996 Mazda B2300
My Chilton's Manual wiring diagrams are limited and don't cover a lot of the vehicle's systems. Need interior lighting/GEM/door sensor wiring and the cruise control wiring. I have a brown wire that the previous owner or someone had simply plugged into one of the fuses. There is no obvious place under the dash where it would have been connected. I found something on the internet that described the wire colors for the cruise, but none were brown and it is clearly connected to the control module on the left front fender well. Need to be sure it's the power source for the system and where is the best place to connect it, even if I have to splice it into a power wire.
Also, my interior lights do not come on. I've bench tested the lights and they work. I've got continuity from the green/orange wire at the light to the GEM module wire. I've checked the left door ajar wires and have continuity to the GEM module in the dash. Grounds show good continuity. Is it the GEM module itself? The door ajar light and bells work with door open....just lights don't come on. I don't think that there's a relay as in the Explorer.
