Wiring harness under driver A pillar | Ford Explorer Forums - Serious Explorations
fatatack911
lake in the hills IL.
02 XLs
Does anybody know what the wiring harness under the driver side a pillar is.
I have a 02 explorer xls. Thanks
Here some picture
I assume you don't have an overhead console?
red/blue: Dimmer switch
yellow/blue: Temp sensor
white/blue : Temp sensor
black: Ground
black/blue: Dome light. This one turns lights on when door is open
green/orange: Dome light. This one is for the reading lights
gray/black: Speed sensor.
yellow/gray: Fuse power. Hot when key in the run position
I'm just shocked the harness is in place. On Gen. 1 and 2 there are no extra harnesses for anything. lol!! When I added the autolamp mirror despite the fact I have an overhead console and moonroof I still had to run my own wires for the mirror.
no i dont have an overhead console
run to the junkyard and get one :) and just plug it in. Not sure if you would need a different headliner . Cant say i looked "up" much .
no i had a moon roof installed, so not enough room for console
yes thanks for all the help
