Wiring harness
Will23
Bend, Oregon
1994 ford explorer sport
I am switching some doors from my 94 Explorer to my 91 Explorer and I cannot figure out how to get the wiring harness out from the door does anyone have any any knowledge of that. I would so much appreciate somebody's input.
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
massacre
‘94 Explorer
‘19 Nautilus
I have had some success with removing the rubber accordion pieces on both sides and then pushing the connectors through 1 at a time. They won’t all fit through at once.
  • Like
Reactions: ~X~
Will23
Bend, Oregon
Are you talking of the connectors that go in the door for the door locks windows and such
massacre
‘94 Explorer
‘19 Nautilus
shran
South Dakota
1992 Explorer XLT
This is exactly how I do it. Remove all the switches from the harness, detach the harness from the door itself where it is clipped on, and slowly feed it out of the hole in the door where it goes in. There is a rectangle plug inside each of the door pillars that it attaches to.
You can also simply unplug that connection inside the pillars and pull the harness off the body that way too. I have a few door harnesses saved in case mine go to shit.
